Anyone using a Lithium Battery?
Discussion in '1st & 2nd Generation 1983-1989' started by Dr.Инженер, Nov 13, 2019.
  1. Dr.Инженер
    Dr.Инженер New Member
    Tennessee
    Anyone here using a Lithium battery on their 2nd Gen? I'm in the market for a new battery and was wondering
    Are their any gains to a Lithium battery?
  2. KarlR
    KarlR New Member
    Esopus, NY
    The Gen5 I bought last year came with a Battery Tender brand LiOn . Worked great this past summer. Never needed to hook up a charger. They are small and light. Foam blocks added to keep it from bouncing around the battery compartment. Not supposed to store on tender or in the cold. I put mine in a non freezing location in the winter and connect to the tender for a few hours once a month.
    Dr.Инженер likes this.
  3. Dr.Инженер
    Tennessee
    Thanks KarlR.
  4. mello dude
    I'm running a LiFePo4 battery for the last 5 years. I like it. It doesn't need charging and all you need to do is bring it in for the winter.
    Also, while sitting, the voltage stays the same in storage.
  5. carlgustav
    carlgustav New Member
    Heart of Dixie
    I have 3 in use, both Shorai and BT types. In my VFR, RSV, and R6. From 2 to 6-1/2 yrs (VFR) old. Never bring them in but they are in a garage and we don't get 'real' cold for any length of time. So far no issues.
    I may update the VFR battery as I understand that when these go, they just go, no warning like you may get with an AGM batt. Someone else may have better info about this characteristic.
    ACE
  6. OOTV
    OOTV Member
    I have two Shorais and one Deltran (Battery Tender). One of my Shorais was installed in my 6 Gen when my stator/RR gave up the ghost. I thought it was history but my friend who helped me get back on the road, took it home and her husband put it on a charger. He called me a day later and said the battery is holding a charge did I want to come and get it?
    I ended up picking it up and put it in my 5 Gen and then bought the Shorai charger for it. This was a few years ago, turned out the Yuasa I put in the 6 Gen to get back on the road gave out, so I then put another Shorai in it, so far both Shorais are doing just fine. While all this was happening, I found a great deal on the Deltran battery with charger, so bought it and put that in my Ducati 900SS. So far I’m happy with all 3.
  7. Diving Pete
    another related question - Is anyone using a quick disconnect on their battery ?
  8. mello dude
    I have been using this quick connect for 5 years. Apparently its a high amperage trailer type connector. Its nice to be able to install or pull the battery out no tools in 5 seconds. I like it. - If I would go to a new battery, I think I would adapt the connector to it.
  9. Dr.Инженер
    Tennessee
    Ha, that's a good idea. Not something I had though about. Going with a smaller lithium batter also will provide extra space to do the quick disconnect. Thanks Mello
  10. Dr.Инженер
    Tennessee
    So it seems it is safe to say NO modification need to be made to the electrical when swapping to a lithium battery?
  11. mello dude
    Before you get one, make sure your charging system is in top shape.
  12. mello dude
    So yeah, the battery installs like any other..
  13. RS125
    I like the idea of a quick disconnect. I have one for the gas tank.
    I've used a battery tender for years with it's remote hookup. It's nice in the winter for a standard battery
  14. wpbarlow
    wpbarlow New Member
    Central New Jersey
    Not quite-- if you totally discharge a regular battery, it will probably recover if you recharge it. The lithium battery probably won't. As a guideline, they like 13.8 and above, according to this article https://www.motorcycle.com/products/lithium-motorcycle-batteries-myths-vs-realities
    I installed my first lithium battery in 2009- lasted 7 years without ever being on a tender. Did need electrical warming up for a minute or two when it was below 40 or so. I found the article tracked with my experience.
  15. mello dude
    The discharge point is one among many, kinda of a "what if" ...... That article is pretty good and lists some things I have noted in the thread previously and also goes with my experience.
    In general, I really like them. They are higher voltage, dont lose static voltage, dont really need a charger, and do the job essentially no maintenance. Whats not to like?
