Auxilliary power supply on 5th Gen 800FiY
Discussion in '5th Generation 1998-2001' started by Fr Dougal, Nov 28, 2008.
  1. Fr Dougal
    Fr Dougal New Member
    Dublin, Ireland
    Guys,
    Can anyone tell me know if the VFR800Fi has an auxillary power source tucked away somewhere behind the fairings? If yes, where could I find it?
    I plan to fit heated grips and a battery status monitor at the weekend so would be handy.
    Ideally I want a switched source and I can connect to a relay for the main feed from the battery.
    Thanks in advance, I searched first but didn't find anything about it.
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Not on a stock model that I know of, if you're speaking of some kind of plug-in power source.
  3. NorcalBoy
  4. drewl
    drewl Insider
    Virginia Beach, Va
    Nope, not stock. Many people have added just what you mentioned without problems, though.
  5. Fr Dougal
    Dublin, Ireland
    I am not talking about a cigarette lighter type socket, more a pair of wires "+" and "-".
    I have two bikes. On the NT650V there is a pair of wires tucked into the fairing at the front with spade connectors, a negative earth and a positive supply which comes on with the ignition. Just looking for something similar on the VFR?
    The heated grips and battery monitor will be permanenty connected, not plugged in.
    I will just find a positive switched feed at the fusebox and bring this to the relay, with a direct positive lead from the battery.
  6. hondajt
    hondajt New Member
    springboro, oh 45066
    I prefer the wiremybike.com site. they offer a plug and play kit that has two loose wires, one positive, one negative.
  7. FrankoQ
    FrankoQ New Member
    Laurel, MD
    You could install a fuse box powered by the battery via a relay.
    Search for fuse panel or fuse box install
  8. FrankoQ
    FrankoQ New Member
    Laurel, MD
