Axle Holder Won't Come Off, Help!
Discussion in 'Mechanics Garage' started by ahoyboyhoy, Mar 30, 2007.
  1. ahoyboyhoy
    ahoyboyhoy New Member
    Los Angeles, CA
    Hi, my name is Winston and this is my first post here. I just recently bought a 1984 VF750F and have run into a problem with some restoration. I'm trying to remove the wheel in order to change the fork oil seals, but right side axle holder just won't budge. The other side came off no problem, however the right side appears to be stuck on their by some adhesive or thread locker. I've tried a 1 1/2 lb dead blow hammer, Wd-40 and Freeze-off. If anyone has a suggestion, I appreciate it. Also, there is no oil in the forks, so I can't just take it to a mechanic...
  2. silverscoot
    silverscoot New Member
    Most high strength thread lockers require some heat to overcome them. Try a little heat on the nut or bolt. A small propane torch is sufficient. I work on heavy equipment and am constantly fighting frozen nuts/bolts, often huge ones up to 3 or 4 inches. I have a number of other remedies if this doesn't work. If in fact there is thread locker on it, the heat should work.
  3. mello dude
    Romania
    Its been a while since I had that bike but - did you loosen the nuts on the bottom of the fork? They act as a clamp on the axle shaft. Once that is done and you have the axle nut on the left side loose you should be able to bang out the axle without a lot of hassle.
    Good luck,
    MD
