back on a Vfr
Discussion in 'Introductions' started by 86vfr, May 16, 2009.
  1. 86vfr
    86vfr New Member
    well i finaly came back to the better side of bikes after getting a 98 vfr and selling it for a 95 900rr then selling that i went back to a v4 1986 vfr750f with all kinds of mods .....well some good some bad or not we will see . ....gsxr front end with 310mm rotors, hypertek space wheels ...super rare from what i have been told 180 rear tire 120 front, fox twin clicker shock, ignition advance, jet kit, and a yosh 4-2-1 header with kerker pipe all high mount runs killer but i have a bit of a snag today went to go ride it ...found it with a flat tire no big deal ill go fill it up and see where the leak is ...well i found the rim is cracked :mad: so on with the fixing this and that to it
    any input def would be cool
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    so this is the bike that you were talking about huh? im wondering what kinda swing arm is on there, because getting a 180 rear tire on a second gen is supposed to have a lot of work invoved in it. well the fact that its already on there and clearances are fine... seems like you should be clear for many aftermarket choices on wheels.:thumbsup:
    lets see some pics!:biggrin:
