Back to life...back to VFR world
Discussion in '1st & 2nd Generation 1983-1989' started by CARMINE, May 19, 2020.
  1. CARMINE
    CARMINE New Member
    Italy
    (NAPLES) ITALY
    Hi everybody. Hope VFR people are overcoming this horrible period. Here in Europe we begin to enter in a less heavy lockdown. So, I decided to do a little maintenance to my 87 VFR 750 F (1st generation). Battery charge, check of all fluids...tires etc…
    I have a question : before to stop my bike for many months I noticed that battery was a little poor of energy after a ride. Last year I replaced the fan thermoswitch (Honda original ) with an aftermarket item that triggers at 85 C°. May be fans start too often or do you think may be my rectifier is going bad? Voltage on the battery measured with engine working at 2k rings/minute was between 13,8-14 volts. Is it good or not? In case of nned of rectifier replacement is it better a SH rectifier for my bike or a FH (mosfet one). I would avoid problems with the stator/alternator. Many many thanks for your advice and stay safe! Lamps to everybody! Carmine
    welcome back, voltage is fine.
  3. calicojack
    calicojack New Member
    Italy
    ITALY
    Il voltaggio é corretto
  4. 34468 Randy
    Can't help you Carmine but good to hear from you again!
