Bad battery?
Discussion in 'General VFR Discussions' started by VFR Love, Jul 17, 2013.
  1. VFR Love
    VFR Love New Member
    New York
    So I left the key on to keep the cooling fan running on my 6th gen after I shut down the motor.
    Unfortunately this leaves the headlight on and worse i mistakenly left it for 30 min. The battery was too weak to restart the bike so I charged it.
    Unfortunately the lowest setting on my charger was something like 5 amps. The battery label states a quick charge at 0.5 amps for 1 hour. So charged it for 15 min. The bike fired right up.
    2 days later did same stupid thing.
    3 questions:
    1)Does it sound like my battery is weak and died too quick with ignition and headlight on?
    2)Did I damage the battery with the quick charge? First time I charged it the battery was bubbling inside and warm to touch when I took it off charge. Second time I used a weaker charger for less time.
    3) Am I being silly leaving the key on to let the cooling fan run? Bike is at 230 ish when I park these days. (90+ degree weather)
    Thank you!
    Running the fan after riding doesn't accomplish much since the coolant isn't circulating, so it won't cool the engine.
  3. VFR Love
    VFR Love New Member
    New York
    I figured it would at least cool the coolant in the radiator and in that way decrease the temp of coolant in the "system". Additionally I figured it would get air movement over the engine.
    So there's logic- but do you still think it's nearly useless?
  4. CRFan1
    CRFan1 New Member
    Northwest Indiana
    Not needed...i am sure our battery is fine. It only hurts if you leave them discharged for long periods.....
  5. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    I noticed that the bike is still hot to the touch 2-3 hours later, if I put a fan blowing on it, It's much cooler after an hour. So, Now I park in front of a box fan that i have set up on a plug in timer. The timer turns the fan on shortly before I get home from work and off an hour or so later.
