Bad knocking noise
Discussion in '6th Generation 2002-2013' started by Deorak, Apr 27, 2021.
  1. Deorak
    Deorak New Member
    Romania
    As you can see from the video the bike sounds horrible imo. It only does that when the clutch is engaged and it sort of fades away as the bike warms up but the sound is still there. Bike has 39k km.
  2. Allyance
    Allyance Insider
    Spain
    East Bay, California
    Don’t ride it till you can pin point it.
    34468 Randy likes this.
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    The bike was in neutral when you let the clutch out I assume? What happens when you let the clutch out
    and the bike is in gear, and on the centerstand?
    Personally I think I'd be looking at the clutch basket assembly. But absolutely don't ride it till you pinpoint the
    problem.
  4. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    I agree that you need to open up the right hand side of the engine to have a look at the clutch basket assembly.
    That video sounds as if there's something wrong with the Primary Drive Gear. It sounds as if there's no damping springs inside the Primary Drive Gear are not doing their job. The VFR800 engine cylinder firing order is "lumpy" and results in one particularly big hit of power once every 720 degrees of engine rotation (this is when cylinder number 4 fires and then cylinder number 1 fires just 90 degrees later). If the damping springs in the Primary Drive Gear aren't working properly the engine will "jangle" the clutch basket exactly as shown in your video. And when you pull in the clutch lever it unloads the substantially, thus the quieter operation.
