Does anyone know if yt12-bs will fit a 4th Gen VFR? https://www.yuasabatteries.com/battery/yt12b-bs/ Thank you.
fitting a battery that sits too low in a gen 4 can be a disaster if the positive terminal touches the metal case. i did that once.
Thank you, I thought battery had a rubber cover at the top in between seat and battery? If not, planning to go with the 9B one.
