Best all around tires
Discussion in '5th Generation 1998-2001' started by Beemer67, Aug 31, 2005.
  1. Beemer67
    Beemer67 New Member
    Colorado
    Hello all. Sorry if this topic has already been covered. Can you please tell me what tire sets you have liked and disliked (2001). I am about ready for a new rear tire. I just got the bike two weeks ago so I am new to VFR's. I do a lot of weekend Colorado canyon riding but mostly it is a daily driver to work. Thank you.
  2. kennymact
    kennymact New Member
    CHRISTCHURCH NEWZEALAND
    ;D Hello and welcome to the world of the vfr. I use bridgestone battlax bt 010 on the front and a 020 on the rear.The 010 is a sport tyre but the rear is a touring,it has a double compound which is supposed to be harder in the middle so you don,t get a flat spot so easily.I had a set of metzlers too which were very good but ended up going to the bt,s again-oh and be very carefull scrubbing it in...good luck 8)
  3. Jake
    Jake New Member
    God\'s Country
    Best compromise between traction (especially cold/wet) and mileage that I've found so far is the Michelin Pilot Road.
    HTH,
    Jake
  4. fyrmann
    fyrmann New Member
    I have to agree with Kenny. I live up in Ontario, Can. and ride with Battlax BT020 front and back. I've put about 16,00Kms (10,000) miles, and the back is in good shape for next year. Only problem is that they are a bit noisy when cold.
    Good luck, Ron
  5. Guest
    Guest Guest
    I'm in love with my Maxxis SuperMaxx tires. I have yet to see any wear on either of them and haven't had them slip or feel unstable yet. I have used the entire width of the 180 rear tread, haven't made it too the sides strips yet, I live in Nebraska!!!
    My front has about 4000 miles on it and the rear is at about 1000. I got a nail in the previous rear at about 3000 but it didn't show harly any sign of wear, I expect to get around 6-8000 miles out of them. They are cheaper than Pilots and handle better than a buddies Pilot Roads on his CBR. Another buddy has Pilot Sports on his 954 and I run from him through corners, but this is due to ability and inhibitions. He has went down now 5 times in the last year...Yeah seriously. Twice doing wheelies, Twice through corners hitting gravel in the early season, and once on a gravel road at low speed. He only gets about 4000-5000 miles on a easy riden tire, he's on his 3rd set this year and they need replaced. I gave under $300 for tires mounted and bal. for the Maxxis SuperMaxx. Ebay is the best place to buy I've found, for NEW tires. I personally don't like Bridgestone as both set I've had started cupping about 3000 and 3800 miles but had good tread left otherwise. I've seen others start cupping even quicker too.
  6. 92yellowveefer
    92yellowveefer New Member
    Hingham, MA (south of Boston)
    Just to throw another option into the mix - I put on a set of Avon Azaros on my 91 and I friggin love these tires. Best all-around balance I've ever experienced. I've currently got 6,000 on the set, and am ready to retire them next season. I will absolutely replace them with a new set of Azaros.
    Good news - there are so many great performance/mileage tires on the market today that it's hard to go wrong. Check out some of the write-ups on motorcyclist.com as well.
  7. RVFR
    Holy Moly another tire question got a love this subject, okay I'll chim in. You can't go to wrong with any of the tires less the chung chings type. I've run Bridgestones 56, 020, 014 all were great. If I was going to be put on the spot I liked the 56r but since they quite making that tire I've moved to the 014 which also worked well just got better millage out of the 56. Now that said I've moved on to the Pirelli Corsas as I'm in the mode to try something new, only have 400 miles, so far so good. I like the profile and read good things about this tire. it's also the rave in Europe. beside the Pirellis came at a great price do to the end of the season blow out special, so for me it was a no brainer. qustion now is the milage time will tell. good luck hope this helped
  8. KC-10 FE
    KC-10 FE New Member
    My vote goes to Metzeler M1's. I put them on my 89 Honda Hawk and I swear that bike is magnetically attached to the ground...
    KC-10 FE out...
  9. RVFR
    Quick up date you might look into the new Dunlop Qualfiers If they would have been out back when I was needing tires I would've tried them on for size. Heard a many a good things Though I'm still sticking to my Pirellis for now.
  10. stephanon2whls
    stephanon2whls New Member
    The 1st State.
    Initial thoughts on Conti Road-Attack Tires - long but a good read for tire shoppers
    The Setup:
    It was finally time for a third set of replacement tires on my 2000 VFR800
    last month. I've worn out two pairs of Michelin Pilot Sport tires after the
    original Dunlop D204K tires. Each rear tire has lasted about 6000 to 6250
    miles and I always change the front at the same time to avoid excessive
    cupping even though there is still plenty of tread left on them usually. I
    guess I'd say I am a mildly aggressive rider - the kind that likes full
    throttle corner exit and wearing the edges of the tire when the road allows.
    I'm not a smoky-burnout-hole-shot-from-every-light kind of hooligan rider.
    I like to connect complex curves in roads with rhythm and speed. I ride
    two-up about 1/8th of the time.
    Switching up:
    I was hoping to continue riding on the Pilot Sport since I had really good
    luck with that tire, but Michelin discontinued that tire and now produces
    the Pilot Power instead. I didn't feel I needed super sport tire at this
    point - I don't track the VFR and I really can't/don't take advantage of all
    the performance of a super-sport tire - even on spirited rides thru the S.E.
    PA. On the other hand, I didn't feel like the Pilot Road was a sporty
    enough tire for me.
    So, I was in tire shopping mode again.... I looked at all the sport touring
    tires out there including the popular Bridgestone combo VFR-listers rave
    about. I ran across the Conti's and read their PR babble and figured I'd
    give their Road-Attack tire a look-see. They have a Sport-Attack tire which
    is more sticky, but I want to get some more mileage out of this set of
    tires. I contacted a Conti PR/sales guy in the US and asked him to describe
    how he sees the Road-Attack and Sport-Attack tires comparing to the Michelin
    line-up.
    Conti guy reply:
    <<<SNIP>>>
    Stephan,
    I have attached detailed information on our Road Attack for your review.
    Our new Sport Attack is comparable to Michelin's Pilot Power and if your not
    going to take your bike to track day sessions I would seriously consider our
    Road Attack which will sacrifice some grip in exchange for longevity.
    Compared to Michelin's offerings the Road Attack falls in between the Pilot
    Sport and Pilot Road in terms of performance, but leans more toward the
    Pilot Sport.
    Long story short Suzuki tested and approved via German homologation our Road
    Attack for use on the GSX-R1000, thus it has very high levels of grip
    however will also offer longevity. For a good tire review that gives a
    comparison of the Road Attack to our competitors please check out
    www.canyonchasers.net where you can read their latest test review.
    I hope this information helps.
    Safe Riding & Best Regards,
    Greg Reich
    Continental Tire North America, Inc.
    Two Wheel Tires
    Sales Manager/Motorcycle Tires
    <<<SNIP>>>
    If your interested in the detailed PR info for the tires (MSWord format),
    contact me and I can email them to you. BTW, BMW has selected this tire for
    the R1200RT as well.
    Lacing up the new shoes:
    Compared with the Pilot sport, the Conti's had stiffer sidewalls and the
    rear tire was a good bit heavier - more than the difference in weight of a
    worn tire vs. a new tire - the carcass of the Conti Road-Attack rear tire is
    heavier. This concerned me a little as did the 1 1/4 oz of weight we had to
    use to balance it - we double and triple checked the balance. If it matters
    to you, the Conti's have a cool checkered flag sidewall decoration and a
    neat looking tread pattern. Anyway, when I got the tires back on the bike,
    it just so happened to be a near 60 degree day here in Northern Delaware in
    January (go figure)... So off I went for a shake-down ride to scuff the
    tires up a bit...
    Miles of Smiles:
    I now have over 200 miles on these tires (in January no less !) and I must
    say I am impressed. The heavier carcass of the rear tire probably slows
    down my 1/4 mile time (which isn't really important for me), but it helps
    dampen road inputs better than the Pilot Sports. Intuitively, I would think
    that the increased unsprung tire weight would make the rear tire skip a
    little more over bumps, but the reality is both the front and rear Conti's
    have a lot of enveloping power (ability to soak up sharp impacts) and are in
    general more communicative than the Pilots were for street riding. The
    increased enveloping power means that the tire can absorb more of the sharp
    impacts than the suspension which means the tire spends more time hooked up
    than skipping over little bumps/seams. The Conti's also have a much more
    neutral feeling in that they require less handle bar pressure to initiate
    and maintain lean angle through turns. I had to re-calibrate my
    press-and-roll coordination because the VFR turns in more easily now... The
    Pilot Sports would sort of 'stand up' the bike so-to-speak while the Conti's
    allow you to transition from turn to turn quickly with less effort. The
    perception I get is that it takes less lean angle and effort to corner with
    the Conti's than it did with the Pilot Sports. Don't get me wrong here...
    The Pilot Sport is an awesome tire and if they were still in production, I
    probably would have bought another set just because I liked them so much,
    but in a way I am glad that I had to try something different. The Conti
    Road-Attack is a newer tire design with (IMHO) a better feel on the VFR. It
    might not be a supersport semi-race tire, but that's not what I need. If
    that's your bag, you might try the Sport-Attack which has a stickier
    compound.
    Only the miles will tell how the tires perform throughout the seasons...
    LINKS:
    Fugi's Factory. Small shop with personal service in northern Delaware. He
    has a great tire mount/balance setup. Coats no-mar mounter and a snap-on
    digital balancer. $20 per loose wheel or $35 per wheel if you drop the bike
    off.
    http://www.fugisfactory.com/
    Conti Motorcycle Tires.
    http://www.conti-online.com/generator/www/de/en/continental/motorcycle/general/home/index_en.html
    Have a nice snowy day in the northeast !
    -Stephan, 2000 VFR800
  11. BobbyKnobby
    BobbyKnobby New Member
    I have been running the Metzler RoadTec Z6. I had run Dunlop in the past but with highway travel the tended to flat in the center quickly. Metzler Z6 has multi compounds, then centers have a carbon additive and last longer with highway miles.
    Hope that helps
  12. VFRMike
    VFRMike New Member
    Paso Robles, CA
    I have been running the Pilot Roads lately and must say I really like them. Have tried most other brands and combos can say that they've all been fine too. Difficult to go wrong with most tires it seems. Typical milage, regardless of tire brand, is 2500-4000 for my sport-touring tires. I've run with more a "true" sports tire but the milage is NOT good. Since the sport-touring tires are not slipping (on me) then why switch to a true sports tire?
    VFRMike.
  13. OhioVFRMan
    OhioVFRMan New Member
    Dayton, OH
    comments on OEM tires? (Dunlop)
    I need a new rear tire too and noticed only one person in this thread mentions the Dunlops which come on the bike when new. Any comments on why you guys shy away from the Qualifiers would be appreciated! Thanks.:confused:
  14. reg71
    Sikeston, MO
    I have never tried them, but I suppose if a deal came up that I couldn't pass up I would get them. A lot of riders who do more touring seem to like the Pilot Road. I tend to a little more sporty riding so I do the Conti Road Attack. They have been working well for me and they are competitively priced.
  15. Spike
    Spike New Member
    I have used the Dunlops and the BT020s -- greatly prefer the BTs. I started using the BT020s after a British mag did a tire comparo and actually used a VFR as the test bike (one of two bikes used), so it was very applicable information. I know I have seen the article typed up somewhere on this site too. Anyway, the BT020s were the tops, but very close behind (one point I want to say) was the Avons. Once I read that, I switched to the BTs and was very happy. Toyed with trying the Avons too, but never did. Now that Avon has just improved the Azzaros to the Storm STs, I am going to try them. Just ordered them last week, should be here on Tuesday.
    MCN just did a review of the Conti's too, used an ST2 or 4 as teh test rig. The reviewer liked them. He too had been running the BT020s. Liked the Contis a little better. Also remarked that they were much easier to mount, if you do your own mounting, that might be an important consideration.
  16. OhioVFRMan
    Dayton, OH
    Conti's
    I used Contis on my KZ 650 many years ago; liked 'em. Thanks for the suggestions. Seems the BTs have some fans.
    :smile:
  17. VFR4LIFE
    VFR4LIFE New Member
    Virginia Beach, VA.
    Tires
    I used the Battlax BT-020's on my 1992 and they were great, long life tires, Upwards of 8000k on each before they were done. My 2006 has Metzler's now, not really sure what style but they are comparable to the BT-020's.
  18. mello dude
    If you are a knee dragger - go with the Dunlop Qualifiers. (I'm pretty well stuck with the Dunlops, I ride hard.) If your a distance sporty toury guy go with the Pilot Roads.
  19. Hondapitbull
    Hondapitbull New Member
    FortWorth,Tx./aka-FunkyTown
    I had Dunlop 207's when I first got the bike then switch to metzlers after 2 nails were found in the rear tire.I rode on the metzlers for about 6 months and didn't like them.I have been riding on Michelin pilot powers ever sense and love em'!
  20. emon07
    emon07 New Member
    Queens, NYC
    I am up north in NYC and I need tires that will warm up when it gets cold, and I also want tires that have good traction in the rain. I am totally happy with Avon tires on my VFR and also have Avons on my Suzuki Inturder. I have had Michelins and Dunlops and they are both great tires. I have the Avon Tires - AV55(Front); AV56(Rear) and I like them a lot better than the Michelin Pilot tires. I have used the Perilli tires before and liked them, but the Avon tires stick good and traction in the rain is great.
