Bike's running funny and FI light comes on
Discussion in '5th Generation 1998-2001' started by hondajt, May 30, 2009.
  1. hondajt
    hondajt New Member
    springboro, oh 45066
    Well, my bike is having issues.
    1.) Its hard to start. I may have to start it three time before it stays running.
    2.) While driving down the road it feels restricted. Like I am also applying the brake. But in the motor.
    3.)The FI light comes on after shifting out of first or second gear.
    4.) Then the throttle becomes very twitchy. Very sensitive and jumpy.
    Any thoughts?
    2000 with 20K, recent oil, spark plug and air filter change. Switched to NGK plugs.
  2. porcupine73
    porcupine73 New Member
    Not sure on the 5th gen but 6th gen there are some pins you put a jumper wire on and the FI light flashes out the code(s) then you can find the troubleshooting procedure in the manual maybe?
  3. hondajt
    hondajt New Member
    thanks. I am so upset, i was forgetting the little stuff.
  4. deepdish
    deepdish Banned
    disconect your battery for 15 minutes and then restart it maybe comp will reset
  5. hondajt
    hondajt New Member
    thanks. I'm going to check the code first, then I'll do that.
  6. hondajt
    hondajt New Member
    How do I get that. A quick search didn't pull anything up, and I am at work, so no access to my manual.
  7. NorcalBoy
    The service manual is here in the WIKI
