bolts in back valve cover?
Discussion in '3rd & 4th Generation 1990-1997' started by Mysta2, Aug 19, 2010.
  1. Mysta2
    Mysta2 New Member
    Little Elm, TX
    Another, what's this do post.
    There are two bolts in the top of the rear valve cover that don't go anywhere (might be M6s, the parts diagram doesn't even show them as far as I can tell) What are these?
  2. tinkerinWstuff
    on the top outside of the cover??
    Those hold the "drip funnel" as I call it. There's a funnel that supposed to catch overflow fuel from the tank, funnel it through a hose, and down to the ground without dripping on a hot motor.
    That's the best I can figure of what you're talking about without pictures.
    If you need one, I may have an extra.
  3. Mysta2
    Mysta2 New Member
    Little Elm, TX
    If you insist :)
  4. Mysta2
    Mysta2 New Member
    Little Elm, TX
    Tinkerin
    thanks, I think I get it. You're calling #11 a drip funnel (bikebandit calls it "RUBBER, PETCOCK HEAT") and the bolts I'm talking about are #24
  5. tinkerinWstuff
    that's for the rubber piece. whether it's a heat shield or rain protector, I dunno, but that's the rubber sheet that attaches there.
    Or I'm senile
  6. tinkerinWstuff
    Having trouble finding it on the fische.
    On this slide, part #10 is very similar to what I'm referring to. It attaches to the same location on the frame with the slots and then has two bolt holes that match up with the holes on your valve cover.
