Braided clutch line VF500F
Discussion in '1st & 2nd Generation 1983-1989' started by jstehman, Feb 22, 2024.
  1. jstehman
    jstehman New Member
    Galfer doesn't have it.
    HEL has the VF series mostly covered with single line setups eliminating the metal pipe piece in the middle.
    Except for the 500.
    They make a 2 piece line .
    They really didn't say why when I emailed.
    Should I just go to a custom line maker?
    Sent from my SM-S911U using Tapatalk
    The old school Russell clutch line was two piece as well. I have one (well two) on my 86.
    Likely because most of the stock one is hard line already and you can remove the rubber sections. Are the otber VF models also removable? Making the kit cheaper and more attractive to buyers?
    I would go one piece either custom or build your own with Goodrich. Or measure what you need with a string or tubing and search for that pre-made length. I do that quite often.
    Jim McCulloch, RogueRC24 and jstehman like this.
