brake light won't light up when front lever is pulled
Discussion in '6th Generation 2002-2013' started by superpsu, Jun 17, 2013.
  1. superpsu
    superpsu New Member
    Cortland, NY
    My brother noticed today that my brake light wasn't coming on when I applied the front brake lever. I checked the rear brake lever and the brake light came on. I pulled the front brake switch off and cleaned the connecters and reinstalled the switch. Still no brake light came on. I ordered a new switch hoping that it is only the switch that failed. I would like to hear some feedback from anyone who experienced this problem. I'd appreciate any responses.
  2. TOE CUTTER
    Does the light come on if you connect the two wires together at the switch?
  3. tinkerinWstuff
    Switch failure is not uncommon
  4. superpsu
    superpsu New Member
    Cortland, NY
    No, the light does not come on.
  5. superpsu
    superpsu New Member
    Cortland, NY
    Thank you tinkernWstuff for letting me know that it is not uncommon for switch failures. I found a switch for $10 so I figured I'd get it and try a new one.
  6. ridervfr
    Too bad you can't get a new one. You could try spraying some OL contact cleaner in there...I had one test ok with a meter, but DOA on the bike, got a new one and problem solved.
  7. superpsu
    superpsu New Member
    Cortland, NY
    The switch is new. got it from Ebay.
  8. tinkerinWstuff
    Always trust eBay
    Think I paid the same price for one from my local dealer and he had it on the shelf. Only part for my VFR he's ever had on the shelf.
  9. jugornot
    jugornot New Member
    Bunnelevel
    If you connect the wires together and get no light its not the switch. Happened to me once but a wire had come off.
  10. superpsu
    superpsu New Member
    Cortland, NY
    I didn't connect the two wires together. The last time I rode was only a few days since yesterday (6/17/13) and the brake light worked when I pulled front lever. If the new switch doesn't work, I'll try to find a wire that may have come off.
  11. superpsu
    superpsu New Member
    Cortland, NY
    Found solution to my problem. It was a bad switch. I thank you all for your input.
