Brake sticking and bike lifting
Discussion in 'Mechanics Garage' started by jondevos, Feb 23, 2009.
  1. jondevos
    jondevos New Member
    Petawawa, Ont
    I have a 2nd gen 1986 vfr 750 which the brakes seam to be rubbing a bit. The bike has some resistance to being pushed or driven. I do not know if its the front or rear brakes as I have no centre stand and therefor cant lift the bike off the ground. Anyone have any ideas as to how I can lift one tire off the ground at a time to figure out which caliper is the problem?
    Work is at a stand still right now so I am on a very limited budget. So buying a bike stand is out of the question. I have new tires I need to have installed as well so getting at least one tire off the ground at a time is a must.
    Can I pull out the pads and squeeze the lever so the pistons come out part way then spray them down with brake cleaner followed by a lubricant with Dot 4 fluid before pushing them back in to see if there is some gunk causing them to be stiff possibly?
  2. Yonan
    Yonan New Member
    TURLOCK, CA
    Do not pull the lever with the caliper off the rotor. It will push the cyclinders right out. You can use a floor jack with a flat board across the top to lift the bike, may take a couple tryies to get it at the right balance point. Be carefull not to drop her. Put it right on the exhaust, it won't hurt it. The headers are very strong. Another method I used in the past was lifting by a couple ratchet tie downs using the rafters in the garage.
    I've read that our master cyls have a hole in the bottom that if plugged will cause the front brakes to stick. Might check that out. Good luck
  3. jondevos
    jondevos New Member
    Petawawa, Ont
    Thanks for the great advice. I was worried about damaging the exhaust. (Although a good excuse to buy aftermarket hehe).
    Haven't heard about this hole that could be plugged. Ill have to see if I can find any information on that.
  4. squirrelman
    YOU can lift the bike enuf to get either wheel up by a clean-and-jerk motion toward the sidestand, pulling the tank into your chest, but you'll need a friend to spin the wheel. (Right hand lifting the frame just above the clutch)
    a quick ride without touching the brakes should reveal a warm or hot rotor on the sticking brake...
    Someone should write up a guide to lifting both wheels on VFRs without centrestands and without roof rafters.
    It took me lots of effort to figure out how to do it sucessfully, and it's still a PIA.
  5. jondevos
    jondevos New Member
    Petawawa, Ont
    Im contemplating lifting by the exhaust with a board but still am worried about damaging it. Anyone else have any ideas. The rafter idea is good, but I dont have rafters to use.
  6. Yonan
    Yonan New Member
    TURLOCK, CA
    I dont actually have rafters either. I used the access to the attic, with a 2x6 across the opening. It is pain lifting these things without pit stands, well worth the money when you can afford them. Kneedraggers.com has good prices on them.
  7. jondevos
    jondevos New Member
    Petawawa, Ont
    Thanks. I have always wondered how the pit stands work. How do you get the bike up onto them? Looks like you need two people to do it.
  8. Yonan
    Yonan New Member
    TURLOCK, CA
    Nope, Only takes one person. I just throw a 2x6 under the kickstand to level out the bike steady the bike with one hand and press down on the handle. Her she is with both ends up. The jack isn't supporting anything. Have to figure something else out when I do the rear shock though.
  9. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    I believe your front brakes are similar to mine(83). The caliper slides on pins. Those may need to be taken out and cleaned. They get gummed up and won't let the caliper release after you let off the brake.
  10. relic rider
    relic rider New Member
    Nanaimo, BC Canada
    I use a engine picker to lift my bikes with 4 tie downs when i need to get the wheels off.
  11. Nitrousva
    Nitrousva New Member
    Richmond
    I do the same thing as Relic Rider, I use my engine hoist if I need both wheels off the ground. For the back wheel, you can put a set of jack stands under the swing arm to hold the rear up.
    Robert
  12. squirrelman
    NOW just think: some blokes have no engine lift, no fancy rear stand, no steering stem stand, no rafters, no convient tree, and no centrestand.
    SO how would u lift the bike with both wheels up??
  13. jondevos
    jondevos New Member
    Petawawa, Ont
    Exactly what I was thinking. I dont really have too much access to jack stands or anything mentioned to help me out at the moment. Ill be taking my bike to my sisters in Markdale who has a garage. I think ill have to do the rafter lift from there. Unfortunately living in military baracks does not provide a good place to work on a bike.
  14. jondevos
    jondevos New Member
    Petawawa, Ont
    Would you happen to have the resource that you read this from? Its something Ill look into, but I dont know where you got it from. Thanks
  15. squirrelman
    STAY tuned, lads, cuz i'll soon be posting some photos and directions how to safely lift your VFR with both wheels up.....using no rafters or special equipment.
  16. jondevos
    jondevos New Member
    Petawawa, Ont
    Ok. I am staying tuned.
  17. squirrelman
    I have a customer's '86 VFR in my shop now that will be getting a front end rebuild, and i'll take photos of lifting and securing method.
  18. Yonan
    Yonan New Member
    TURLOCK, CA
    I read it in a post here about someones front brakes locking up. If I remember right it said there was a hole in the bottom of the cyl that may or may not be covered by a rubber flap. The purpose of the hole was to let fluid bleed back into the cyl when you let off the brake lever. If plugged it would cause your fronts to stick. I haven't had to work on mine yet so I have not seen it with my own eyes yet.
    Squirrel man seems pretty well versed on our bikes maybe he can gives us the benefit of his wisdom.
  19. Yonan
    Yonan New Member
    TURLOCK, CA
    Looking forward to it.:thumbsup:
  20. jondevos
    jondevos New Member
    Petawawa, Ont
    Thanks. I think I just might drain the brake fluid. Clean out the master and flush with some new Dot 4 fluid. See if there is a hole in there that just might happen to be blocked. While Im at it Ill pull the calipers apart and clean then. Better call the dealer for a seal kit.
