break and clutch levers
Discussion in '1st & 2nd Generation 1983-1989' started by Rudydereza23, Jun 15, 2020.
  1. Rudydereza23
    Rudydereza23 New Member
  2. raYzerman
    raYzerman Member
    Millgrove, ON
    If you compare the black adapter pieces to your OEM levers.... if they actuate the clutch and brake switches in the same way and the plungers for the master cylinders in the same way, then you are good to go. There are really only two types used on most Hondas. I could tell you better if you had pics of your levers.
    Those should fit. I use CBR1000F and 90-97 VFR master cylinders with my 86 levers.
  4. Rudydereza23
  5. raYzerman
    raYzerman Member
    Millgrove, ON
    Um..... No way to conclusively tell without the levers actually off the bike. Have to see switch actuating end and the m/c plunger end.....
