Brembo Brake Caliper Upgrade
Discussion in '6th Generation 2002-2013' started by AWP34, Aug 6, 2015.
  1. AWP34
    AWP34 New Member
    Can any one tell me the model number of Brembo Brake Calipers that are a direct bolt on for my 6th Gen VFR 800 non ABS.
    Thank you for your time.
  2. AWP34
    AWP34 New Member
    Will the Brembo P4/34 front brake calipers work with an 08 VFR 800 non ABS
    and the P/34 rear ?
  3. NorcalBoy
    The first problem is there are no Brembo calipers that are a direct replacement for the front left caliper on a 6g VFR.
  4. OOTV
    OOTV Member
    Negative...
