Brembo Radial clutch upgrade with pics
Discussion in '6th Generation 2002-2013' started by CandyRedRC46, Feb 7, 2014.
  1. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    [​IMG][​IMG][​IMG][​IMG]
    I just installed a Brembo radial clutch master cylinder off of a 2009 Ducati 1100 monster. The ratio has been improved slightly with the Brembo have a 1mm smaller bore 15mm vs 16, for less effort and more feel, with a wider friction zone. I already had 100 pound Barnett clutch springs, so the lessened effort is a god send. As an added bonus, the previous owner had 6 position adjustable levers already installed, which can adjust the friction zone from at the bar to about 1.5 inches off of the bar. So all in all I would say that this is a great modification for those seeking less clutch effort and greater clutch lever feel.
  2. tcooper27
    tcooper27 New Member
    Columbus, IN
    How much of a difference would you say that made in the width of your friction zone? My clutch seems to have that light switch problem other people have. Stock is 1/4in and I'm thinking about trying a 12mm one I found off a ducati.
  3. DaHose
    DaHose New Member
    Napa, CA.
    Ooooooohhhhhhhhh ....... that's purrrrrrty.
    Jose
  4. silverbullet132
    silverbullet132 New Member
    Anyone know what ratio the brake master is on a 5th gen? I want to improve the brakes on it, but keep the linked brakes.
  5. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Are you saying that the stock friction zone is 1/4 inch or the stock master? 1/4 inch makes sense for the friction zone. Mine felt even shorter than that. This helped a lot, but I don't think that I could put an exact number on the friction zone length for you, I can just tell you, that it's much better now. I think a 12mm master would be way too small, but it is worth a try. Go for it and let us know.
  6. Scubalong
    Nicely done as always CR :thumbsup:
  7. tcooper27
    Columbus, IN
    Sorry, I meant the stock clutch master piston is 1/2inch, so about 12.7mm
  8. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Damn you're right. I need to stop believing everything I read on the internet.... Lol
    Now I should probably look up what size the 2009 Ducati 1100 monster is.
    Probably that 12mm that you were talking about.
  9. tcooper27
    Columbus, IN
    From what I've been able to gather (reading on the internet!) a radial master acts like a much smaller diameter regular clutch, to the point where most people say a 19mm radial is very comparable to a 14mm regular. Maybe I need to look into the one like yours instead if it's really 15mm!
    The 12mm one I've been looking at is a regard style clutch, off of early 2000s models. They're remote reservoir brembo's with gold bodies and silver levers. Any other color lever was 13mm.
  10. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
  11. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
