Broke a Piece of my Carburetor but is it Important? '86 VFR700F
Discussion in 'Mechanics Garage' started by wiltdavi, Aug 26, 2014.
  1. wiltdavi
    wiltdavi New Member
    So I was trying to remove my carburetor of my '86 VFR700F and it just would not come off the boots. Long story short I broke a piece of the carburetor but I have no idea if it is important. It looks to me like it was a mounting point and the whole that came out of it was caped but I am no expert. I have attached multiple view to hopefully show someone enough to help me determine what, if anything, I need to do. I figure my options are to;
    1) Do nothing
    2) Epoxy the piece back on
    3) Epoxy the whole closed without the piece
    4) Replace the part
    I just want to resolve this correctly so if I need to replace the part I will replace the part but from what I have read I think replacing this part is a big pain.
    Any help is greatly appreciated.
    See the attached photos and let me know if there is a different angle you need.
    20140414_172735_resized.jpg 20140414_172759_resized.jpg 20140414_172822_resized.jpg 20140416_184840.jpg 20140826_094117.jpg 20140826_094150.jpg
  2. Allyance
    Allyance Member
    East Bay, California
    It's been a few years since I have had my 750F carbs off, but that looks like a hole that was drilled during manufacturing, then plugged. Since broken piece is solid, I would JB-Weld piece back on, but make sure JB-Weld seals hole as well in case it comes off again. Clean surfaces thoroughly.
  3. Quattro73
    Quattro73 New Member
    Norway
    Norway
    Agree, must be welded. Either weld the piece back on, or just weld over the hole, if left open the carb will not work properly.
    3) Epoxy the whole closed without the piece - will work too :)
  4. kennybobby
    kennybobby New Member
    You will be okay to just epoxy over the opening. No need to try to attach the stub, just close the opening to keep air out. i would take out the little brass cap also so there is nothing loose to open up the hole. Don't block off the large tube from the tiny port hole drilled thru the side, just the external opening exposed at the fracture needs to be covered.
  5. wiltdavi
    wiltdavi New Member
    Thanks to everyone confirming that all I need to do is seal the exposed area.
  6. TOE CUTTER
    I may have a spare carb if needed. Got a box of individual carbs so the probability is good. Standard cost, shipping and 18 cold beers.
  7. wiltdavi
    wiltdavi New Member
    Thanks TOE CUTTER for the offer. I am going to try what I got and if it does not start I will take you up on that offer.
  8. TOE CUTTER
    Just PM me if needed.
