Bushings to replace on 86 VFR750F Forks?
Discussion in '1st & 2nd Generation 1983-1989' started by Dukiedook, Jul 21, 2010.
Tags:
  1. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Hey guys,
    I will replacing the springs and seals and oil washers on my 86 VFR750fg that will be staying stock. Any bushings I should order that get beat up/degrade that I should replace also?
    Upper and lower fork bushings turn from a dull grey to copper-colored when they're worn.
    Might be a good idea to replace washers on bottom bolts.
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    Maybe the snap rings?
    Mine were rusted and when I removed them they became pretty beat up.
  4. Dukiedook
    Kansas City, USA
    Yep, planned on changing those (washers) also.
  5. TOE CUTTER
    How many miles does the bike have? I would not replace the bushings unless worn as Squirrel stated as they are a bit pricey.
  6. slowbird
    slowbird Member
    Toronto, Ontario.
    ^^ Good point. ^^
    Pull everything apart and see what it needs first. Even the bushing on my VF500 forks were fine after 58,000kms.
  7. Dukiedook
    Kansas City, USA
    I'll check to see if they need replacing, I assume you guys are talking about BUSH, GUIDE
    51414-MN4-003, and BUSH, SLIDER 51415-MN4-003?
    They are not too expensive, about $7.30US and $9.30US each.
