California Smog Crap Removal
Discussion in '1st & 2nd Generation 1983-1989' started by BLIGHT, Feb 4, 2012.
  1. BLIGHT
    BLIGHT New Member
    Hey guys,
    Today I removed all the smog stuff... canisters, several feet of hose and other crap from my '86 VF500 today, and I blocked off all the vacuum ports on the carbs.
    I've done this before on multiple bikes before with no problems. Well... I turned a very well running bike into one that now starts very hard, won't idle consistently (750 to 3000 rpm), and is starving for fuel when ridden even with just a little throttle. Really weird!!
    Here's the CA smog plumbing diagram:
    Am I missing something, or are there some others here that have gone through the same thing? I think the problem is stemming from the vacuum activated fuel supply valve, and a lack of vacuum possibly?
    Any thoughts?
    Thanks,
    BLIGHT
  2. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    You probably know this already but on a bike without the PAIR kit there is a rubber hose running from the vacuum take off on (as you sit on bike) the rear left intake manifold. This goes to the petcock. You need a vacuum in this line for fuel to flow. Not a big vacuum either, you can take the hose off and suck it and hear the fuel flow if your floats are empty. If you have that covered I cannot help. It does sound like the bike is running lean so are you sure every port has been blanked off?
  3. TOE CUTTER
    Per the diagram line #6 looks like the float bowl vent, that WILL need to be open to atmosphere and check to make sure the pet cock vacuum line is not kinked.
  4. BLIGHT
    BLIGHT New Member
    Thanks guys, I think the fuel petcock is malfunctioning. I can turn it to ON and RES, and fuel flows (without a vacuum in the port) That's not right, and it might be a weak 'pressure' or an intermittent flow. (i did a quick test with gas flowing into a cup) I have a spare petcock in the garage and it seems to work correctly.
    I'm gonna swap them today and see if I can make it run properly. Seems weird that this petcock 'malfunction' happened right after I took off the evaporative plumbing. It was running fine before! I may have plugged the bowl vent and that could hamper fuel flow. I'll make sure it's clear.
    Thanks for the tips and I'll let you know if I solve it!
    BLIGHT
  5. BLIGHT
    BLIGHT New Member
    Hey, it was the bowl vent line... I plugged it yesterday when I was plugging the vacuum lines. Removed the plug and now it runs like a champ again!
    Makes sense, fuel can't flow into the bowls unless the air has a way out!
    Thanks for the help!
    BLIGHT
  6. TOE CUTTER
    I love a happy ending.
