Cam chain tensioner question
Discussion in '6th Generation 2002-2013' started by vpr135, Apr 29, 2020.
  1. vpr135
    vpr135 New Member
    Norway
    Hi.
    I have replaced the cam chain tensioner, but how do I tension/ adjust it?
    I see there is kind of an eye on the top, but do I turn it, break it of or what?
  2. raYzerman
    raYzerman Member
    Millgrove, ON
    Normally you just pull the tab out and the spring will unwind...
  3. Terry Smith
    Just to expand on Rayzerman's post...the tensioner has been shipped to you with a locking device inserted so you can install the tensioner without applying tension to the chain. When you pull that locking device out, the tensioner spring will be released to apply tension to the chain.
