Can i use a car regulator on my VFR?
Discussion in 'Mechanics Garage' started by jades, Mar 6, 2011.
  1. jades
    jades New Member
    Hi
    I have a 1999 VFR 800, got it for a month now, the bike doesn't charge the battery. Checked all the wiring, the alternator makes good power, figured it was the r/r. Its quite hard to get hold of a R/R were i am. I thought i could use the rectifier and regulator from a car. Connected up the rectifier, getting good DC Voltage off the rectifier, But i dont know how to connect the regulator to it, has anyone tried this before, and could you help me?
  2. reg71
    Sikeston, MO
  3. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    An automotive regulator won't work. Most motorcycles use a permanent magnet charging system, and automotive systems have a "switchable" field, meaning that the alternator output is turned on and off as is required. The permanent magnet alternator is constant output, so it requires a different style of regulator.
  4. Bryan88
    South Africa
    Durban, South Africa
    I've used a car rectifier plate and regulator on an old CB1100RC and that seemed to work. It's tricky but can be done.
  5. jades
    jades New Member
    Thanks, i try and make it work, will keep you updated if it works or not.
  6. Lgn001
    Lgn001 Member
    My old CB1100F also has an automotive-style alternator/charging system, and I suppose that an automotive regulator could be adapted. But a permanent magnet alternator (VFR as well as most newer bikes) is ALWAYS in output mode, so a different type of R/R is required. The significant difference in motorcycle R/Rs are the components used inside; they are either SCR-type or MOSFET-type.
    There might be some new bikes that use a switchable-field alternator, but most do not. If your heart is set on experimenting, do be cautious. The unloaded output of an alternator can cause injury and/or fires.
  7. jades
    jades New Member
    I gave up trying to get the car regulator to work, to complex for me to do. I ordered a Shindengen FH012AA R/R off ebay, got it yesterday, installed and working today, yay! Back on the road. It took forever for it to get here, waited like a month, but it works brilliantly.
