Can't read guages.
Discussion in '1st & 2nd Generation 1983-1989' started by Calbob, May 11, 2007.
  1. Calbob
    Calbob New Member
    Unless the sun is right over my shoulder, I cannot read the gauges. The plastic is a bit cloudy, and the needles don't stick out enough.
    I look down and say....
    So, I cleaned the plastic, no help, then at night the light bulb is so dim that I look down...
    SO, is there a solution to making these gauges readable?
  2. Gatekeeper
    Gatekeeper New Member
    Novus in the stages needed to recon your lenses. (I've only once needed all three stages. On a XLCH.) Just follow the directions.
