cant start new to vfrs
Discussion in 'Mechanics Garage' started by vfr700kid, Apr 26, 2010.
  1. vfr700kid
    vfr700kid New Member
    just bought a 87 vfr 700...when i hit the start button the solenoid tries to click and then will start smoking...starter does nothing....any ideas i am wondering if the motor is seized up. let me know thanks
  2. paul.miner
    paul.miner New Member
    Quick way to check is to do a rolling start in second gear (helps to have someone push you). Turn the bike on, put it in 2nd, and have someone push you while you hold in the clutch. Once going, release the clutch swiftly but smoothly. If you suspect the engine is locked, be prepared for your rear wheel to lock.
  3. elwray
    elwray New Member
    Central NJ
    The smoking would have me a little worried but let's start with, do you have the battery fully charged?
  4. vfr700kid
    yeah i will try that later thanks but i tried turning the crank but yeah didnt move so i think it is locked up thanks though
  5. vfr700kid
    oh and yes a brand new charged battery
  6. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    I forsee an engine pull and teardown in your future, I am in the same boat on one of my 750's.
    Good luck.
  7. vfr700kid
    yeah thats what i am thinking haha i am prolly just gonna sell it for parts
  8. macosman
    macosman New Member
    remover the stator cover. Make sure ignition switch is OFF. and try to turn crank with 14mm wrench. take the plugs out and it should move easily.
    put a pan under the stator cover. you'll get a small amount of oil.
  9. squirrelman
    NO NEED to remove stator cover to access end of crank since it's available under the( about) 3" diameter "timing cover" on the clutch side without drips.
    Turn--or try to-- with 17mm socket.
    Remove plugs and pour 1 oz motoroil/kerosene down each hole, then wait for 2 or 3 days b4 turning. Leave plugs out.
  10. vfr700kid
    yeah i think it is lcked up i just poured some stuff marvel stuff in the cylinders and yeah the crank wont turn thanks guys for the help and when i pour this stuff in it....it comes out of that hole on the side of the head any ideas?
  11. adamjenkins
    adamjenkins New Member
    Massachusetts
    It is broken..
  12. squirrelman
    It woooda been smart to try turning the engine b4 you bought it, eh ??
  13. zielarz
    zielarz New Member
    detroit
    Hey if u gonna sell parts let me know man...I need few little things.....if not u have to look for engine I guess...
  14. TOE CUTTER
    I would suggest plucking the heads off to get a look at the bores if you are sure it is locked up.You tried to turn the crank as suggested by the Squirrel?
  15. vfr700kid
    yeah tried turning it manually already...and yeah i should have had him turn it over when i bought it....the guy even said if he had a key he could try to start it.........i shoulda coulda woulda....for 350 bucks what should i excpect haha
  16. vfr700kid
    oh zielarz....what kind of parts would u be lookin for?
