Carb Balance.
Discussion in '1st & 2nd Generation 1983-1989' started by TPR42, Jan 14, 2009.
  1. TPR42
    TPR42 New Member
    Southport UK
    Could you live with the settings in the picture ?
    I've messed about for around 1 hour and the more I fiddle with the adjustment screw the settings all end up out of sync, so I got them best as I could I think they might be ok.
    Please could somebody advise as I've still got the gauges set up and if I need to mess about anymore today then it saves me putting the covers back on and tools away.
    See what you think anyway :smile:
  2. dizzy
    dizzy New Member
    MN
    That looks pretty good. I use mercury sticks myself...a little easier to read. You'll probably see a slight change every time the throttle shaft comes to rest at idle, that's normal.
  3. TPR42
    TPR42 New Member
    Southport UK
    I know what you mean m8, there is slightly different readings but I think overall this is the best I could get them set up :smile:
    That will do for me dizzy, I'll fasten everything up and take her for a test run, thanks pal for the reply :wink:
    Regards,
    TPR
  4. RaceAce
    RaceAce New Member
    preston, lancashire, england
    I would be more than happy with those settings, if i had carbs :tongue:
  5. TPR42
    TPR42 New Member
    Southport UK
    Thanks m8, appreciate the reply :wink:
  6. squirrelman
    b4 checking synch it's a good idea to check valve clearance and compression.....
    your readings (nice photo) look quite acceptable.
  7. TPR42
    TPR42 New Member
    Southport UK
    Hello Mr Squirrelman :smile:
    Yeah that's a job I want to do when we get our Winter over with and then check the Valves.
    I think though at the moment I've got some of the main jobs done since I bought the old Girl :wink:
    Regards,
    TPR
