Carb clean...choke circuit fuel pickup tube
Discussion in '1st & 2nd Generation 1983-1989' started by squirrelman, Oct 28, 2010.
  1. squirrelman
    Choke (enrichener) fuel tubes should be probed with a stiff steel .010" or .012" wire.
    You need some persistance to keep poking through the FIRST hole at about 30mm, then keep on using carb cleaner and compressed air and more poking until you've reached the whole length of the tube, which is about 60 mm.
    (2nd gen, others similar)
  2. crustyrider
    crustyrider New Member
    North Country, New York
    is this to ensure that the choke is "choking" correctly ?
  3. mandolinman
    mandolinman New Member
    it worked and it did take persisitance. A guitar string at .010 worked great. Bike starts right up from dead cold. Thanks
  4. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Compressed air +1.
