Carb service specialist
Discussion in 'General VFR Discussions' started by squirrelman, Nov 23, 2008.
  1. squirrelman
    With over 30 years experience working on carbs from exotic sportscars, racecars to bikes, and having owned many VFRs ( and lots of other bikes mostly from the 80s and 90s) over the past 24 years, i feel i'm well qualified to offer carb cleaning and rebuild service to members here.
    My service includes careful inspection, ultrasonic cleaning of jets, replacement of any parts found unservicable, blow-out with high pressure filtered air, setting float levels, remove mixture screw seals, precision assembly, bench tests to verify operation, and visual synchronization. Jet kits can be installed also.
    Much INexperienced carb cleaning needs to be done again....and again because it takes lots of experience to do the job right the first time, every time.
    I aim for about 2-3 week turnaround time, and winter is the best season for me.
    My plan is to have a fully cleaned and ROAD-TESTED set of '94-'97 carbs available on an exchange basis for immediate shipment. Also '86/'87 700/750
    Put them in a box and ship. ( I'm willing to help you over the phone to remove and replace.)
    If interested, just PM me here or at my e-mail.
    Good luck, SMan. Like I always say, "No good deed goes unpunished".
    BTW, the IRS said they don't have a tax id number on record for your business and the local business licensing authority in your area said the same thing.........
  3. supervfr
    supervfr Banned
    How would someone be able to go about setting the float level when the carb doesent have gasoline in it? How do you know where the fuel level is supposed to be?
  4. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Good service to offer squrriel.
    By the way, looked up Cyrus Eaton; interesting cat for sure. A testament to good capitalism.
    BZ
  5. squirrelman
    Super.....
    answer: float height determines fuel level but they're different things; floats are set without fuel.
    and i have a fuel tank above my workbench for carb testing purposes.
  6. supervfr
    supervfr Banned
    i see how the float works, I just do not know at what specific level the fuel is supposed to be at.
    Different carb designs would have the level at different heights or depth or whatever. I know how to measure it. but measuring something doesent help if you do not know at what measurment to set. it
  7. NorcalBoy
    Send your carbs to SMan. I don't mean to be a dick, but you really need outside assistance at this point. After the last couple of months, this whole carb thing doesn't appear to be your forte. It is also readily apparent that you are not in this boat by yourself.
  8. supervfr
    supervfr Banned
    Ill figure it out eventually. Iv got all winter long.
    Its either one of 3 problems now. either i didnt get them clean enough. there isent enough gas in them. or there isent enough suction.
    now that i figured out about the coil the problem is much much much much more specific and easyier to read.
    having multiple problems combining symptoms really made it hard to pinpoint the exact problem.
