Carb/starting issues
Discussion in '3rd & 4th Generation 1990-1997' started by Rckslick333, Aug 12, 2020.
  1. Rckslick333
    Rckslick333 New Member
    Why is it so hard to start my gen 3 after I pull the carbs off? I didn’t miss a hose or anything, petcock is on. I replaced the boots, put the carbs back on and can’t get it running.
    its always like this. Maybe poor fuel pressure I’m not sure. But once I get it running, it runs and starts just fine.
    thanks in advance
    what did you change ? when carbs are dry it can take alot of cranking to fill them again. good time to bypass the pump relay for fast filling.
    Rckslick333 likes this.
  3. Rckslick333
    After about an hour of cranking, or more, finally got it running. So annoying. Only thing I changed was new carb boots :). Thanks for the reply!!
  4. squirrelman
    you can fill the carbs with a bottle b4 trying to start, but the pump relay bypass is useful too. doesn't make sense to overstress the starter motor and battery just to fill carbs.
  5. Rckslick333
    How does someone bypass the relay?
  6. squirrelman
    reading the relevant pages in the honda service manual would be a good start. ;) alot of discussion on this topic here.
    just one wire but u need to no where 2 stickit. :cool:
  7. Diving Pete
    I have the exact same issue with my wife's CBR400rr if its not been ridden for a couple of months or she has run out of fuel whilst riding. it now has a small piece of wire in the tool kit for this reason.
  8. ridervfr
    Belgium
    what about using a nurse bottle with the tank off and going from there? I never had to use jumpers on the fuel pump relay, I guess I am not as swift as "the Squirrel Man"
  9. Rckslick333
    Is anyone? Lol!
  10. squirrelman
