Carb swap for different years
Discussion in '1st & 2nd Generation 1983-1989' started by ibonzi, Mar 14, 2014.
  1. ibonzi
    ibonzi New Member
    My carbs are trashed. Has anyone tried carbs from newer years?:glee:
  2. Chris71Mach1
    Chris71Mach1 Member
    Grand Prairie, Texas, United States
    86 and 87 should be interchangeable
    Sent from my SPH-L720 using Tapatalk
  3. TOE CUTTER
    Chris is on the money, 86-87 for gen 2, 83-85 for gen 1.
  4. ibonzi
    ibonzi New Member
    What about 90-97. They look the same
  5. squirrelman
    Gen 3 carbs are unlike gen 4s in a few ways, not easily interchangable i think.
  6. squirrelman
    Not quite.
  7. squirrelman
    Who told you that ?? Carbs usually have to be broken to bits before they're can't be repaired. Even the worst fuel problems won't trash carbs, but sloppy work will.
  8. ibonzi
    ibonzi New Member
    Well......94-97s 750 wont work:crushed: Shame as they are flatslides and of better design. The spacing both ways is off and not worth the effort to make work...
  9. squirrelman
    Semi-flatslides you mean. Again, what makes you think your carbs aren't repairable ??
  10. ibonzi
    ibonzi New Member
    Carbs
    Im sure they are repair:tongue-new:able I was just looking for a bit more umffffff lol
