Carb swap on 86 VF500f
Discussion in 'General VFR Discussions' started by Marco Es, May 25, 2025.
  1. Marco Es
    Marco Es New Member
    Spain
    Hi all, greetings from sunny Granada.
    Just new to the forum. I recently bought a 1986 VF500f. It has been stood for the last 25 years. It had a full service prior to this, so everything is immaculate EXCEPT for the carbs.
    Completely trashed, they had not been emptied , so a real mess inside.
    So I managed to pick up a very clean set of pre 86 carbs - big question will the work on the 86?
    I have replaced the carb to manifold rubbers (2mm bigger than the 86) will the jetting be ok? 86 carbs have main 95, older ones have 90.
    Thanks in advance
    On a stock bike, the stock jetting from a different year will likely be just fine.
    Keep in mind 86 were gravity fed and prior had fuel pumps. The inlet spigot is in a different location and some adaption will be needed.
