Carb sync issue
Discussion in '1st & 2nd Generation 1983-1989' started by mpadgett88, Dec 18, 2012.
  1. mpadgett88
    mpadgett88 New Member
    medford, oregon
    so I cleaned my carbs and i am trying to sync them but its not working out. its an 87 vfr700f2
    I am using 1/8 drill bits to hold butterflys.
    The problem is I cant sync them number 1 when the butterflys are closed no bit satys a little open. when I put the bit in the others dont open enough to slide the bit. I adjust the screws and they open a little bit but not enough to get the bits in I have loosened the screws to the point where they have fallen out.
    any ideas?
  2. mpadgett88
    medford, oregon
    also wondering the floats? I measure 7 mmish from the top of the float to the wall accross?
  3. squirrelman
    Try using a strip of paper (about .004") to synch the butterflies or, better, line up the first of the small progression holes equally. A drill bit is worse than useless for the task ! Start by adjusting the idle speed screw so the first hole JUST becomes visible under the throttle plate on that carb, then match up the others.
    Best after bench synch to check it with gauges while the enguine is warm and idling.
    I'd advise you not to change float adjustments since the bike was running OK except for fuel pump issues.
  4. mpadgett88
    medford, oregon
    ive sat and tinkered with it for 2 days now. using that air valve or what ever. could never get any butterflys to match it the #2 the one without the screw.
  5. squirrelman
    The carb with the idle adjustment screw is where you need to start !
  6. mpadgett88
    medford, oregon
    thats the one I am starting on. but its all wacky man. This carb is driving me nuts and I hate nuts unlike your furry self
  7. mpadgett88
    medford, oregon
    Drinking a beer now perhaps itll enlighten me
  8. ridervfr
    Stick with it!! its like he said above, start with base carburetor (idle screw) and play peek-ah-boo with the rest regarding lining the butterfly up with the first HOE. Start by turning the screws on the 1,3,4 carburetors respectively. Hope you have your trusty manual too! Have a good flash light too, not a piece of shit, as shedding light on the subject is super important. There is a sequence to it too.
    Once you bench synchronize them, you should be good to go, could always put some gauges on them later if the bike does'nt ride well a cunts hair off throttle. Mine does, so I didnt bother, as its a severe pain in der-arse to do it. Cheers and dont let the bastards get you down! :smile:
  9. mpadgett88
    medford, oregon
    Ive read and used everythig in the manual and else where and nothing worked the base carb wont even close all the way. so I dont really see how I can get them all to match as I said before the screws fall out.
  10. mpadgett88
    medford, oregon
    squrrelman how much you charge for carb cleaning and a sync haha
  11. ridervfr
    Too bad your not in south FL. Squirrel would help you oot though...I call him Eichornchin though...
  12. squirrelman
    What could be keeping that butterfly open ?? Since each synch screw adjustment may slightly affect the others, i'd suggest you set the 3 other screws at their midpoint of travel, and begin there.
    Did you remove the rod linking the front carbs' butterflies to the rears or did you remove the airbox base from the set ??
  13. mpadgett88
    medford, oregon
    I did remove the base before I took i off the bike then ut it back on and then removed from bike as I read it was better not to remove plenum.
    I removed no linkage but I am tonight to carb did and soak em better then ill try to sync after.
