Carbs need to be synchronized
Discussion in '3rd & 4th Generation 1990-1997' started by jorgescar69, Apr 6, 2021.
  1. jorgescar69
    jorgescar69 New Member
    La Puente, CA, United States
    Need some help.
    My carbs are out of wack and and I forgot the order of the little screws under the carburetors to get the sync rite!
    the sequence is very important. start with carb that the idle adjustment screw controls.
    if the carbs are mounted you will need a proper set of gauges; if off the bike you do a bench synch.
    jorgescar69 likes this.
  3. jorgescar69
    Hey Squirrel...
    They on the bike... front 2 are good. Dont know if the next one is LR or RR.
    Gage's are mounted yo. IMG_20210405_214357_553.jpg IMG_20210405_214357_553.jpg
  4. squirrelman
    match the vacuum on the front 2 cylinders, then match the 2 rears together, then work on the f/r linkage screw to balance fronts to rears. there is some interaction between screw settings so it takes awhile to get it right.
    snap the throttle a couple times anytime you move a screw so things settle into place.
  5. jorgescar69
    to.
    I been on it since 2pm westcoast time.
    How is that Western New York weather?
    Riding yet?
    I left Westfield in 2016.
    Sunshine and blue skies. Mountain roads with no residents!
  6. squirrelman
    sure but you might slide off to the west any time. :oops:
    nice and 70 degrees this week, been riding for a month already but my main bike has a split tire valve that i can't fix.
  7. jorgescar69
    But I'm gonna ride the hell out of ACH, GMR, ORTEGA, and 39 before I fall into the Pacific!
  8. jorgescar69
    IMG_20210801_213507_367.jpg IMG_20210801_200852_361.jpg carbs have finally got synchronized. Played with the needles a bit to work out the flat spot from 5500 to 8000 rpm.
    I'm happy!
  9. jorgescar69
    20210722_010415.jpg and it was hot!
