Carburettor sync. - VFR750F, 1986
Discussion in '1st & 2nd Generation 1983-1989' started by Rune, May 14, 2019.
  1. Rune
    Rune New Member
    Norway
    Hi there, Does anybody have some guidelines for carburettor synchronization, specific for the VFR750 year 1986? Info about the adapters needed etc? Br Rune
  2. hondaman219
    hondaman219 New Member
    maine usa
  3. Rune
    Rune New Member
    Norway
    Many thanks for quick respond and info from that website.
    About the tools...
    Do you have some information about the vacuum line adaptors for each carb and special tool for adjustment screws?
    The manometer gauges is ok.
  4. squirrelman
    you'll need a glove if you're reaching into the hot V to twiddle screws. if the bike runs OK, you won't need to (and don't) turn any screw more than about 1/16 turn or even less. sequence is VERY all-important. be sure to blip the throttle a couple times after any screw turn to let the adjustment settle in.
