Cbr Wheel conversion on vf500
Discussion in '1st & 2nd Generation 1983-1989' started by Dominik, Mar 29, 2024.
  1. Dominik
    Dominik New Member
    Austria
    Hi I just fitted cbr600 wheels and the tire is rubbing. Is somebody riding the f2 wheel conversion to and which tires are you running to make this work ?
    Or how can i make the 160 wheels to fit?
    The consensus is you have to run a 150/60-17 tire on the 4.5" rim.
    Dominik likes this.
    Also it appears it is an Avon tyre. They run wide. A Michelin or Pirelli run closer to "advertised".
    I have 5.5" rear wheel conversions on two VF1000. One has a 170/60-17 Pirelli that measures 168mm and fits perfect. The other has a 170/60-17 Avon that measures almost 180mm and occasionally rubs the chain.
  4. Dominik
    Dominik New Member
    Austria
    Ok in another forum they rode wrote i can ride a 160 60 from Dunlop but im not sure
  5. Dominik
    Dominik New Member
    Austria
    Ok thanks im looking to it
  6. Dominik
    Dominik New Member
    Austria
    But the vf1000 has a wider swing arm or not?
    It was just an example of how different tire manufacturers can vary greatly in the actual sizes of tires.
  8. Dominik
    Dominik New Member
    Austria
    A ok thanks what do you think of the idea that dunlop 160 will fit or not?
    I have no fucking clue. Have you researched if Dunlops typically run wide or not?
    If you are just gonna start throwing rubber at the problem, why don't you just buy a 150 series and be done.
    That is PLENTY of tire for a VF500F.
  11. Dominik
    Dominik New Member
    Austria
    I want to ride a tire as thick as possible for the aggressive look.
    Good luck.
    Captain 80s out.
    Dominik likes this.
  13. Dominik
    Dominik New Member
    Austria
    Thanks will post a Update
