Center stand helper
Discussion in 'General VFR Discussions' started by RobVG, Sep 13, 2014.
  1. RobVG
    RobVG Member
    White Rock BC
    The first time I put the bike on the center stand, I tweaked my back. There isn't much to hold on to and you have to bend over when you lift. A piece of rebar and a few minutes took care of the problem.
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    If you tweaked your back you need to work on your technique. There's no real lifting involved so your back shouldn't have an issue. Your legs should be doing all the work.
  3. sunofwolf
    sunofwolf New Member
    what another problem that BB didn't cause, can't be!
  4. 74ullc
    74ullc New Member
    Gulf Coast, Texas
    SOW....WTF.....again? Did your response contribute anything helpful or meaningful to the thread? Stay out of other people's threads with you're crap until you have something valid to contribute.
  5. duccmann
    Nope, nada zilch, nothing as usual.......
  6. Badbilly
    First off, SOW doesn't have much of a handle to grab onto either. This is part of the reason for his frustration. This is a medical condition for which there is no cure. ( Micropenis)
    Back to the guys bike.. It's a 1984 and unless the many pix of same lies, there is not a lot to hold onto to lever the bike up onto the centerstand. We might assume that unless having owned an 84 with a centestand and maybe having a tweaked back to start with, maybe thinking we got it all figured out ain't as good as a bigass chunk of rebar and Archimedes was spot on.
  7. Voided76
    Voided76 New Member
    San Diego, CA
    centerstands are easy.
    step it into the ground, press the front brake, keep pressure on the center stand, as you shove and load up the frontend with a good downward push. as the frontend begins to rise back up, let go off the front brake, the bike should then recoil backwards, walking right up onto it's center stand.
    it's really nothing to get bent outta shape about...
  8. 34468 Randy
    Gotta say I have never heard of it being put on the stand that way. Are you astride the bike while you do this. I wanna give that one a try. Mayby SOT will try also and drop his bike again and blame it on putting 1.75 gallons of gas in the tank instead of the usual 1.5. But his frame sliders will protect all.
  9. sunofwolf
    I have a reg stand, so only the bike shop use center stand with its perfectly level Floor. I don't think BB uses center stands either-its not needed when you use other peoples bikes-you have to wonder though if they catch on and leave the brakes broken. My jerry can is 1.5 gals and I don't need much gas to go 30 miles that my limit tell I figure out what I am doing wrong-my wrists hurt those stock clip-ons are too low-I only have a 2 inch raise on them. I think the vfr has to be setup for the rider because the way it comes is not too good-a Suzuki 1000 is actually lighter-much faster.
  10. Badbilly
    Anybody confused as to which type of centerstand is being misgussed.
  11. duccmann
    Hey BB...think he has a hard on for you...every single uninformative message he leaves he's got your name in it. Hey girly boy there's other forums for that
  12. Voided76
    Voided76 New Member
    San Diego, CA
    Seriously sow. Leace badbilly out of your irrellevent bullshit so I dont have to be irrationally angry at him for scarring your poor little mind amd heart. Also. Stop with the irrellevent shit.
    My way of centerstanding, you are in the saddle. If you drive the centerstand down with one foot, the bike will center itself. Thats when you load yhe brakes and let it rock itself back onto the stand.
  13. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Never tried it while on the bike, just not tall enough I guess. But it really isn't that hard off the bike though. I can almost do it barefoot, and definitely with just sandals or flipflops on. My '99 goes up really easy, but it's all in the technique. IMO anyway.
  14. Voided76
    Voided76 New Member
    San Diego, CA
  15. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    He sure makes it look easy.
  16. Badbilly
    Noooooooo! A bloody Yamaha on our beloved turf.. Probably trick photography IMO.
  17. Voided76
    Voided76 New Member
    San Diego, CA
    The fz1 is a tough act to follow. I nearly got one. But I was sick sick of the bees. In my exhaust.
  18. Voided76
    Voided76 New Member
    San Diego, CA
    It is very easy btw. Once you realize when you put your weiggt on that center stand pedal on the saddle and it just sticks in place, one solid rock of the bike and it rolls straight back onto it. No rebar needed haha
  19. duccmann
    Voided...you must be 6'2...I would love to see a video of you doing it with your VFR. You have to have both your feet flat footed on the ground right?
  20. duccmann
    I'm only at 5'6 and have lowered my bike 1 inch and still am able to grunt it up no problem. Technique technique technique and practice
