chain and sprocket replacement
Discussion in 'Mechanics Garage' started by azviffer, Feb 14, 2024.
  1. azviffer
    azviffer New Member
    Denver, CO
    i have a 2014 Interceptor and need a new chain and sprockets. my searching has led me to believe i need a 525 chain with 110 links, 43 tooth rear sprocket, and 16 tooth front sprocket. can someone here confirm is this is correct? the only mods i've done are the addition of Givi bags, i haven't done anything to the chain/sprockets.
  2. bmart
    bmart Insider
    Charlotte, NC
    Are you just trying to replace stock sizes on an OEM chain/sprocket combo that's worn out? Many folks improve the drive system with other parts/ratios.
  3. azviffer
    azviffer New Member
    Denver, CO
    just replace with OEM, i'm happy with all the stock specs
  4. dlegg
    dlegg New Member
    Vancouver Island, BC
    I can confirm that the specs you noted are correct for a 2014 VFR. I just installed the identical chain and sprockets on my 2014.
    azviffer likes this.
  5. squirrelman
    so, what did you pay for the set USD $ ?
  6. dlegg
    dlegg New Member
    RK GXW chain & JT sprockets $222 CAN ($164 US).
    RK UTC2100(50) chain breaker $121 CAN ($89 US).
