Chain issue near Valencia
Discussion in 'Europe' started by tomcatek, May 1, 2024.
  1. tomcatek
    tomcatek New Member
    Spain
    Hey,
    Is there anyone living around Valencia and have a chain tension key for 8th gen (2014, 800?
    Wysłane z mojego SM-G991B przy użyciu Tapatalka
    with a toothed ring adjuster, a flat-faced punch or drift or big screwdriver applied with very light hammer taps will usuaally get the eccentric moving . just be certain the bolt that holds the adjustment is very loose. ;) it might help to shoot some lube in back of the ring before moving it. only real danger this way is potential damage to a tooth on the ring if the adjuster wont move freely, causing excessive hammering, tapping on almost any tooth is possible if one or two are f-ed up or missing.
    NOT recommended IF U HAVE THE PROPER TOOL :cool:
  3. tomcatek
    tomcatek New Member
    Spain
    Yeach.. that's why I wanted to ask first :D
