Chain sounds real loud going over the sprockets
Discussion in 'Mechanics Garage' started by DanDog, Aug 30, 2008.
  1. DanDog
    DanDog New Member
    Newfoundland
    Chain going over the sprockets sounds really loud and my mechanic figured a new chain would be the solution. I have a 2000 vfr 800 with 22000kms. Did anyone else ever have this problem and what is a good replacement chain??
    original chains need replacement at around 20k miles, so you're nearly due. replace both sprockets too.
    i like the RK-XSO chains
  3. 34468 Randy
    I got 45,000 km out of mine but it was really in bad shape when I (or the shop) replaced it. And yes, while you are at it, change the sprockets too. It is metal on metal and both surfaces wear. To put a new chain on and not to replace the sprocket, would subject the chain to excessive wear. But WTF do I know. I have for the first time, just done an oil change on mine.
  4. DanDog
    DanDog New Member
    Newfoundland
    thanks for the advice all
  5. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    And if you cant afford a new chain...ear plugs ...just kidding
  6. powerslave
    powerslave New Member
    winnipeg,manitoba.
    I always thought a chain was good until it hit the ground!!!!
    Then I'd walk home and order a new one!:tongue:
  7. 34468 Randy
    HEY ! ! ! ! We aren't talking north main taxi cabs here. We are talking about our beloved VFR's Go back to the Villa and think it over.:vader: And that could be a long cold and lonely walk where yo live. I broke down in your neighbourhood on my bicycle a couple years back.
  8. powerslave
    winnipeg,manitoba.
    Yeah,It's a long walk home from town, but luckily the Villa,or the ever trusty Green Brier is always available for drowning of sorrows and a skanky peeler!!!!
    Yes, life can be good,even with a broken bike!!!!!!
    Somehow, a 10 mile walk wasn't so bad back when I had my sexy mullet and a belly full o' Bud!!!!!
  9. 34468 Randy
    Are you old enough to remember Gladys who shook up the Villa regularly. She was blond and about 350LBS. What a gas.
  10. powerslave
    winnipeg,manitoba.
    No,I must be a tad younger than you,But I do remember that queer little bartender who used to do his flamin' dance:bootyshake2:between pouring drinks!!!:lalala:
