Chain stretch limits
Discussion in '5th Generation 1998-2001' started by VFRanimal, May 5, 2007.
  1. VFRanimal
    VFRanimal New Member
    Tucson, AZ
    My chain wear indicator sticker on the chain guard is missing. Is there another way to measure how much stretch I have left until I need to change the chain/sprockets? I couldn't find anything in the manual.
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    MIne was missing as well on my 93. I changed mine when I started having to adjust it what seemed like every other day.
  3. mello dude
    Romania
    Stock chains will go around 20K miles. Another hint that the chain is toast is to look at the spocket teeth. If they are starting to look more rounded and less pointy - it's time to do the replacement job.
    MD
  4. yep
    yep New Member
    Ohio
    Also - pull on the chain half way up the travel of the back sprocket. if you see more than half a tooth then it is time to switch them out
  5. nozzle
    nozzle New Member
    Southern Maryland
    :rant:
    So far, 2 months and 3k miles in, the worst part of my 06 VFR is the chain adjustment marks... common Honda... a paper sticker on the plastic chain guard to compare the tops of the sprocket teeth? you can't do better?
    :rant:
  6. nitronorth
    nitronorth New Member
    Kamloops, BC
    just go with what the fellow above says by checking half way round the rear sprocket..that will tell the tale very simple..if shes tight, happy, ....
