Changing brake pads on a 4th gen
Discussion in 'Mechanics Garage' started by chillee151, Jun 7, 2008.
  1. chillee151
    chillee151 New Member
    concord,ca
    Got some new ebc pads for the front. Whats the best way to release the pressure on the calipers enough to slide the rotor back in between the new pads?
    Cheers,
    Danny
  2. Rev
    Rev New Member
    Olympia,WA
    All the CSM says is to push the pistons back in. Are you having trouble with them moving, like they are stuck or something?
  3. RVFR
    As long as I have own 4th gens this is one item I have not done on a 4th. On other bikes if I couldn't push them in by hand I used a C-Clamp and cranked - pushed the piston back in, also used a small piece of plywood on the good side of the caliber as to not leave marks. I mean we are talking what 250 thousandths, should be easy enough. Just keep an eye on the fluid level in the reservoir.
  4. mello dude
    Romania
    Take the top off the master cylinder resourvoir, so no air pressure can build up and make it tougher to pull your pistons back. -- Very important! --- put a few rags around the top of the resourvoir and watch the fluid level like a hawk! When you push the pistons back the fluid level will rise and can over flow. Occassionally when I have had a brain fart and forgot about it, I had nice brake fluid a over my beautifull bike. SOB! -If your seeing the level get too high a scringe to suck out some fluid will work.
    Then to move the pistons lot of times just a long screw driver to pry (carefully,slowly! finesse!) beween the rotor and the old worn out pad will do it. (Stick a piece of card board on the rotor side so you dont scratch it.) Then if the sucker is hyper stubborn,
    a C - clamp will work like a champ. BTW - if it is the hyper stubborn side of the fence, a good flush out wouldnt hurt.
    You probly got gunk around the pistons binding it up some.
    MD
  5. mello dude
    Romania
    What no front pad change in 11 years of ownership? Dont use the front brake? (OK - I'm just harrassing you. :wink:)
    MD
