Cheap garage door opener
Discussion in 'Mechanics Garage' started by dugdthug, May 19, 2013.
  1. dugdthug
    dugdthug New Member
    Tulsa,OK
    Man garage door openers are expensive! Go to your local pull-a-part and rip out a homelink system from a sun visor. Open it up solder wires to the first switch(one on each side of the switch). Buy a cheap momentary switch from RS or your local electronics shop. Solder the two wires to it(switch is just to complete the circuit). Wire in power and ground. I "waterproofed" mine with rtv but make sure you set it first! I installed this on my '90 mounted the switch above the starter button. Cost about $8.
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I usually buy my openers from Amazon: $10-$15. Cheap and they work, what more can you ask for.
  3. dugdthug
    dugdthug New Member
    Tulsa,OK
    Yeah its pretty much a diy thing. You do get the satisfaction of mounting a switch where ever you feel is comfortable. I had a skylink system on my '07 RWB wired to my horn. Just wasnt waterproof enough.
  4. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    Might fine redneck engineering there Dug, I likey!!
  5. Jackstand Johnny
    Jackstand Johnny New Member
    Do you have any pics of the process? ;Im terrible at understanding stuff like this by just reading it. Do you feel the homemade opener you made yourself is of higher quality or practicality over the $10-$15 ones that FJ12 says you can buy online?
