Clean and Green
Discussion in 'General VFR Discussions' started by FearIsGood, Aug 22, 2008.
  1. FearIsGood
    FearIsGood New Member
    Clean and Green (Updated 3/1/9)
    Cleaned up the first time since the spray can special, just made it back this week from NC (from Cen OH). I like it more every time I see it
    :treehugger: :treehugger: :treehugger:
  2. Robert111
    Robert111 New Member
    Paintrock TN
    I like the flat OD color easy to touch up,
  3. RVFR
    Great for those covert operations
  4. drewl
    drewl Insider
    Virginia Beach, Va
    got some stars and stripes for it? or maybe an air force insignia?
    It does look cool.
  5. VT Viffer
    VT Viffer New Member
    South Carolina
    Just needs a sportbike tail (like a CBR 600/1000RR) to finish the look. I still don't like the exhaust "caves" in the back.
    The olive drab color is really uber-cool, though. I think that a few "well-placed" flat black warnings (aircraft style) would accent it nicely.
  6. derstuka
    San Diego, CA
    How about a shark mouth like off of an old P-51 Mustang or something? That would look sweet on it.
  7. CARMINE
    CARMINE New Member
    Italy
    (NAPLES) ITALY
    hi,
    'Stuka has always a certain sense of humor you can't find easily elsewhere...
    Ciao Buddy, what's up ?
    Lamps (of course) to all VFR owners.
    Carmine
  8. hondawolf
    hondawolf New Member
    Livermore, Ca
    What paint did you use? Currently doing body work to repaint mine, debating getting a nice professional job or doing it myself. Just hate to spend the money, and end up low siding or something. Verse doing myself, then I could always touch it up if something were to happen....
    Looks good, like the color. Nice with the lower muffler too. Too bad the tail doesn't look as smooth without the exhaust in there.
  9. VsVFR
    VsVFR New Member
    Western KY
    Looks Great! That low mount micron was weirdin me out until I saw the last pic. I take it there are no clearance issues with the pipe and rear tire/swing arm?
    Vs
  10. FearIsGood
    No clearance issues, I had to space out the pass peg with some washers and then it was fine. Less than an inch but I'm not worried. Still trying to figure out filling in that tail, probably a winter project.
    It was krylon camo paint from autozone and lots of sanding.
    The P-51 mouth is quite likely, just trying to figure out which one of my 'artistic' friends should do it.
  11. Joey_Dude
    Joey_Dude Member
    North Georgia
    All that needs now is some machine gun exhausts:
    Oh and maybe put in a flame thrower for the popo! :vfrshorty:
  12. mello dude
    Romania
    Ok you WW2 buffs, was it P-51 or P-38 Spitfire?
    MD
  13. Scubalong
    Nice thought
    Nice thought Joey:rofl::rofl:
  14. Seidts
    Seidts New Member
    Southern Vermont
    WWII Military airplane history 101. Abbreviated...
    P-38-Lightning twin engine boom tailed fighter bomber later used for recon.
    P-39 Aircobra Slow, single engine bathtub that got shot down alot.
    P-40 Warhawk, Tomahawk, single engine fighter that did a lot of shooting down. Made by Curtis aircraft. (Glenn Curtis being the fastest man on earth via a V-8 motorcycle on 1-24-07 going 136.47 MPH)
    P-47 Heavy, but nearly indestructible fighter, Saw the later part of the war.
    P-51 Fastest of all the U.S. planes. later "D" models had a bubble canopy.
    If you are looking for sharks teeth, look up pics of the P-40. It had an air scoop under the propeller that made a pretty mouth.
    Any questions?
    Class dismissed.
  15. VsVFR
    VsVFR New Member
    Western KY
    Fearis, you could try buying an aftermarket undertail(hotbodies) and hinge it and make an undertail trunk. Might be a little fabbing involved, but it might be possible. Either way, awesome looking bike. Just mean!
    Vs
  16. Hotbrakes
    Hotbrakes New Member
    Richmond, VA
    With all the talk of WWII fighter looks, the finishing touch to heal the gaping hole in the back would be a pair of cylinders shaped like bombs with the little fins on them. You could even do a cluster with 4 or 6 small ones. Attach a switch to a servo so you can drop them on unsuspecting tailgaters. Fill the "bombs" with concrete and they will surely back off. Flat black that pretty can too.
    Any luck with the shark mouth?
  17. FearIsGood
    Flat black the can!? It's way too pretty for that.
    Winter is here and I'm fiddling a bit. Will most likely have the exhaust back up under the tail in a couple weeks. Also sent that picture and a few other shark mouth pictures to a graphic guy I happen to be related to. Might try the vinyl route, just have to make sure it sticks.
    I have been procrastinating because it is all snow and below freezing temps. You just can't put something brand new and exciting on a bike and then not immediately ride it!
  18. FearIsGood
    Alright, well the P40 theme is almost finished. The fairings are being worked on and I've now changed the exhaust.
    Oddly, it makes an interesting nekkid bike, like a roid raging SV :rolleyes:
    Had a friend help me gut the stockers, too cheap to buy a full set up and just couldn't figure how to fill in under the tail. We decided that looking like the stock exhaust was no good (heat shields too flashy for flat also), the green throws subdued out the window. So new tips, hollow cans, and bead blasted the outside for an interesting finish. Sounds like I'm running off the cat but deeper! :eek: (saved the titanium in case I ever have to meet a track noise req)
    Not sure how I feel about the color of the exhaust now, I'm almost considering flat blacking those. Thoughts?
  19. Hotbrakes
    Richmond, VA
    Freakin awesome! I just flat blacked my aluminum cans on the RC51 and they look great. You should do just the tips of yours, like the last 6" or so for a jet engine look. You should also paint the passenger pegs or scrap 'em. How did you make those tips?
    I need to find a set of junk plastic and tank so I can hook mine up too. Can't wait to see it with the mouth on.
    [​IMG]Looks much better than crappy polished aluminum. I used hi temp flat black, sanded them lightly, and did a couple coats.
  20. FearIsGood
    The cans look good on that RC! Dang I want one of those.
    I definitely agree about the pass pegs, they really break up the lines. Flat black soon to come!
