Cleaning 20 year old dirt in engine bay
Discussion in '5th Generation 1998-2001' started by OnlyVfr, Oct 25, 2020.
  1. OnlyVfr
    OnlyVfr New Member
    Ireland
    Hi all,
    Taking things apart etc and now I am facing engine bay cleaning. It is very old dirt, maybe corrosion too, don't know. This is the picture of it, thermostat and all piping have been removed so I have full access to it now.
    What would you use to clean such a hard dirt / corrosion (?) ?
    Don't have sand blaster and using power washer is not an option atm.
    Thx
  2. 34468 Randy
    That is some major gunk there. I would stat with a really good soaking with engine degreaser and or WD40, agitated with a stiff parts cleaner brush. And finally a good cleaning with a liberal soaking and agitating with a strong soap solution and a rinse. See where you are at after that.
    OnlyVfr likes this.
  3. OnlyVfr
    OnlyVfr New Member
    Ireland
    That will be a f nightmare of a job...
    dhinson66 likes this.
  4. raYzerman
    raYzerman Member
    Millgrove, ON
    BTDT.... remove all hoses, get a toothbrush with degreaser/naptha/wd40 (mostly naptha). Let it soak a while first. Small wire brush can remove stubborn stuff... when you're done, soap and water or my fave, isopropanol is less messy.
    OnlyVfr likes this.
  5. OnlyVfr
    OnlyVfr New Member
    Ireland
    "This is the picture of it, thermostat and all piping have been removed so I have full access to it now." :) did that. Ok, will try naptha. Have isoprop, thank you for your advice. Next weekend will be fun...
    raYzerman likes this.
  6. mello dude
    Since you said the T-stat is removed and hoses too, block all open ports, and as a first pass , I would go with Purple Power (degreaser) and toothbrushes......
    Then take a data point and go from there... I have a local guy that does vapor blast, I may be tempted to do that.....
    Lots of ways to go... not sure what is available in Ireland.....
    OnlyVfr likes this.
  7. Waylander
    Waylander New Member
    Waltham Abbey, Essex, UK
    Brake cleaner is great on oil and grease, and cheap detergent like “elbow Grease” yes I know but it’s a real name, and a selection of good stiff brushes
    Did this with that combo[​IMG]
  8. squirrelman
    it helps the chemical cleaning process if the engine is warmed up.
  9. OnlyVfr
    OnlyVfr New Member
    Ireland
    Engine is out, frame sent for powder coating, doing valves soon...
  10. squirrelman
    powder coating a shiny alloy frame doesn't sound like such a good idea. :oops:
  11. OnlyVfr
    OnlyVfr New Member
    Ireland
    Have done it few times on different bikes, if you prepare it good it will work well.
  12. NorcalBoy
    I've done it twice. Didn't have any issues. It was an improvement for both.
    pi-on likes this.
  13. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    Mostly used citrus-based degreaser and scrubbed with various brushes.
  14. DaHose
    DaHose New Member
    Napa, CA.
    That situation looks like a good time to use a small sandblaster, but with baking soda as the medium. It will blast well, not damage the aluminum, and cleanup after just needs some warm water. Just do it somewhere outside. That dust goes EVERYWHERE!
    Jose
  15. w3bdevil
    w3bdevil New Member
    Finland
    Hyvinkää, Finland
    Here's what mine looked like before cleaning. I went with citrus-based degreaser as GreginDenver already suggested and used a toothbrush and some small wire brushes which I think were originally meant for cleaning spark plugs. Turned out ok but it took some time.
  16. mello dude
    What is the name of the product you used?
  17. GreginDenver
    Denver, Colorado
    I would have to look at the bottle to be able to tell you the brand name. I'm in the middle of a move right now (changing from Denver to Huntsville Alabama) and everything I own is in storage while my new house is being finished.
    One thing I learned about citrus degreasers is that some brands work really well and others are awful and nearly useless. Do not buy a citrus degreaser labeled "foaming" because they're useless.
    mello dude likes this.
  18. fink
    fink Member
    Do you have a before picture?
  19. GreginDenver
    Denver, Colorado
    I think my old Photobucket account is on its last legs, not very functional, but I'll try...
    Here's my engine's "V" before cleaning.
    Yeah, the engine on my '99 didn't start out as hideously dirty as some others I've seen pictures of.
    It's strange, when I go to "edit" the pictures show up just fine but when I click on "Save Changes" I get that "photo with a big red "X" on top of it" thingy.
    fink likes this.
  20. fink
    fink Member
    Cheers for that. Considerably cleaner that the ones I have attempted.
    Yeah I’m in process of removing all mine from photobucket. I’ll see if I can find some for you.
