Clock setup issue
Discussion in '7th Generation 2010-Present' started by nikkon, Jun 26, 2017.
  1. nikkon
    nikkon New Member
    Netherlands
    Bucharest
    Hi all,
    I know it sounds stupid and it is but following the manual I'm not able to set the clock time on my vfr 1200f. Any one had the same as me?
    Sent from my E6653 using Tapatalk
  2. John O
    John O New Member
    Whidbey Island, WA
    On my 2014 VFR 800 it stopped being re-settable about 6 months ago. I just gave up.
  3. nikkon
    nikkon New Member
    Netherlands
    Bucharest
    Not supporting here ;) I tried 50 times and i'm not capable of doing it.
  4. nikkon
    nikkon New Member
    Netherlands
    Bucharest
    Nobady alse can help?
  5. duccmann
    HONDA
  6. CBRent
    CBRent New Member
    Mine too. It just stopped working at some point. The buttons skip past the clock when I cycle thru odometer and miles...
  7. nikkon
    nikkon New Member
    Netherlands
    Bucharest
    This is insane. Really
  8. RllwJoe
    RllwJoe Insider
    Try this option. At precisely noon or midnight (12:00) remove and replace your negative battery cable.
    The clock should read the correct time.
    VFR4Lee likes this.
  9. A.M
    A.M Moderator Staff Member
    Have you seen this from the other guys?
    http://www.vfrdiscussion.com/index.php?/forums/topic/77406-how-to-set-the-clock/
    http://www.vfrdiscussion.com/index.php?/forums/topic/79221-setting-the-clock-2012/
    Not much info there, but maybe enough? Good luck. Simple things like this can be extremely annoying.
  10. CBRent
    CBRent New Member
    Solved the issue on my bike.
    I had to cycle thru the odometers. I started at Trip A and cycled to the total mileage odometer. Then I held button B until the hour started to flash. I was able to change the time. Of course, I didn't know what time it was. So, I tried to start over. The hour wouldn't start flashing. So, I cycled thru the odometers again. That seemed to work. My Big Viffer now knows what the correct time is.
    Good luck!
