Clutch kit?
Discussion in '5th Generation 1998-2001' started by chris in va, Jan 10, 2008.
  1. chris in va
    chris in va New Member
    I have to sell my 99 here very soon and need to get the clutch changed out before I do. Ideally a factory Honda kit would be best, but I did see that Barnett kit on ebay for $140.
    The bike needs tires too, so not sure if I should just do those instead...
  2. pjvtec
    pjvtec New Member
    West Allis, WI
    tires or clutch ?
    If the clutch slips or drags alot, do the the clutch. I've seen Barrnet clutches work and not work.The fiber plates were too thick. Go OEM. If the clutch is fair, you can't go wrong with fresh meat. You can see the tires, not the clutch.
  3. reg71
    Sikeston, MO
    I just got done using the barnett set. worked great. smooth action now. no complaints. I think I even posted a couple pics of the process.
  4. chris in va
    I'll probably just do the Barnett kit then. The dealer wants $230 for a factory Honda set. I'm not made of money right now.:cool:
  5. flameface
    flameface New Member
    New England
    bead blast your steel plates to rough 'em up and install a fresh set of springs. it'll get the new owner about a season if he's gentle on it.
