(Clutch replacement) Whistling noise during start up.
Discussion in 'Mechanics Garage' started by Scubalong, Jul 11, 2017.
  1. Scubalong
    Hola Mofos
    After replace my clutch for the 3rd time.....There is still whistling noise during start up.
    Here is the story
    Order Barnett kits installed and it hard to start at first but finally it start but there is a slipping (whistling) noise when I start. I took the Barnett off and reinstall my old clutch and the issue going away.
    I then order the OEM kit and noticed the friction plate are different from Barnett and from my old kit :Frusty:
    I when ahead and install the kits per the diagram. I noticed the manual only called out friction plate A and B
    WT..............:Crazy:
    After reinstall the new OEM kit the noise still there. What the hell going on here....?
    Can one of you Guru shine some light for me? I am at lost at the moment.
    I have done this many time and have no issue until now. Thanks in advance .
    The Barnett kit came with 1 bigger in ID and 7 regular friction plates
    The OEM came with (1) number 7, (6) number 8 and (1) number 9.
    My old friction plate came with 2 (Big OD) friction plate
    New clutch from Barnett
    Here is OEM
  2. derstuka
    San Diego, CA
    Maybe it is turbo charged boss?! Brrraaaaappp
  3. Scubalong
    Here is the noise that really bother me
    Sent from my SM-N910V using Tapatalk
  4. Terry Smith
    I haven't listened to the clip Long (I'm meant to be working). Is the clutch pulled in when it whistles or is it out?
    I put an EBC kit in my 5G last year, no issues at all. The bigger ID disc goes in first and sits over/around the washer and judder spring (6 and 14). The judder spring is meant to be fitted with a specific alignment.
    Whistling at start up would likely be a dry bearing somewhere, I'd take a look around the end of the pushrod where it contacts the clutch lifter plate/bearing. If needed you can pull the pushrod right out from the slave cylinder side.
    Scubalong likes this.
  5. Scubalong
    Hey Boss is the midget let you out yet? Where the hell are you?
  6. Scubalong
    It's only whistling during start up in Neutral so the clutch is close. I will try to start in gear with the clutch open to see if the issue exist.
    Yes I install the BIG ID friction plate in first as shown on the Diagram.
  7. Terry Smith
    I listened to the video. That sounds more like the starter clutch screeching to me. If it only happens on startup, seems less likely to be the clutch.
  8. Scubalong
    Terry you are right. Further examination I have found the noise came from starter clutch and not disengage like it should.
    I compare to my buddy VFR after starting the engine I hit his starter button again and his is quite Vs. Mine is not. I will have to take a look at diagrams and try to pin point the rubish. Thanks for follow up on the issue. Greatly appreciated. Have a cold adult beverage on me mate.
    Terry Smith likes this.
  9. derstuka
    San Diego, CA
    Boss, the midgets let me out for a little bit, then its back to the cave!
    In the video, it sounds like the starter is running on.
    You say the new OEM friction are "different". Are they thicker, or what?
  10. derstuka
    San Diego, CA
    I'd be looking at the starter, not the clutch
  11. derstuka
    San Diego, CA
    Btw boss, you said 'third" VFR clutch. Was that all for black beauty?!! You been lending your bike to Ricky Gadsen at the drag strip?
  12. Scubalong
    Boss read the first post. Took me 3 time with 3 different set of clutch. Yes the vfr is having new clutch for the 3rd time. She is reaching 100k miles in anytime now.
  13. reg71
    Sikeston, MO
    I switched to a Barnett way back and it still seems pretty good. Did you torque everything to spec in order?
    +1 for looking at starter.
  14. derstuka
    San Diego, CA
    I think we should all chimp in and buy him a new one.
  15. reg71
    Sikeston, MO
    thanks for chimping in jason.
    maybe if he puts his $6 footlong services to work he can make up the money.
    He could sell street taco
  16. Scubalong
    Reg
    I order Barnett kit and it not work as it should, took them off and replace with the Original and it still making the whistling noise , took that off and install new OEM clutch and the problem still there...I even disassembly the starter clutch, inspect clean reinstall with oil and all torque to spec.
    The problem still there...........F..............I am gonna drive it this way until she go ..........:Target:
  17. Scubalong
    Thanks Boss
    I like the RWB or Silver will do :Hug:
  18. reg71
    Sikeston, MO
    I think I know the problem, Long. On the left handlebar, there is this lever that you are supposed to pull in when you get ready to shift.
    1. pull it in
    2. click the shifter into gear
    3. gradually release the lever while gradually applying throttle
    Problem solved.
    :Baby:
  19. Scubalong
    :Jaw: Is that how it work.....F.........I have been do it wrong all this time:Loco::Lol:
    Don't you have a starter on your death engine? Thinking of replacing the Starter but I cannot effort buying every part without knowing the Cause :Noidea:
  20. reg71
    Sikeston, MO
    yeah, but you have to take the whole engine if you want it. I'll be moving soon so I'm trying to downsize.
