coil votage question
Discussion in 'Mechanics Garage' started by crotch fire rocket, Jul 22, 2010.
  1. crotch fire rocket
    crotch fire rocket New Member
    st.paul mn
    Ok so after about a month of riding and then pulling my carbs back off because my bike runs perfect for about 20 minuets then no longer idols right. I thought it was in the idol circuit so i synced my carbs then adjusted idol bleeds bam everything works good. but no after 20 min to 30 min idol goes to shit feels real fat starts missing. well i checked input voltage to coils individually and i am only getting 3-4 volts at an idol. voltage will increase to 7 upon throttle opening. So my question is what voltage should i see going into my coils?
  2. TOE CUTTER
    What is system voltage? What do you have at the battery? Your bike will not idle correctly with low system voltage.
  3. crotch fire rocket
    st.paul mn
    never mind r/r and electrical system is fine. my carbs are going fat i gotta lower my needles.
