Hi All, Browsed the forums may times but never had a reason to post. Hoping I can get some confirmation. As a new owner of a 2015 VFR Deluxe (White) I'm trying to source oem side cases but none to be found except red. It seems the vfr800x crossrunner cases will fit once I can locate the footpeg rubber which I think I can do with my dealer. However, I can't seem to determine if the white color on the 800x and the 800f are the same. Code for the 800x panniers is listed as NHB53P. Does anyone know if the white between these 2 models is the same. I'd hate to buy only to find out the color is off slightly as they are very pricey. Thx
