Color of gas cap ring?
Discussion in 'General VFR Discussions' started by vfr249240, Sep 24, 2021.
  1. vfr249240
    vfr249240 New Member
    Florida
    Does anyone know the Honda color code or if not the code then what color silver would most closely match the gas cap bolt ring. It is for a gen 8 but I would think other generations might be the same color. Thanks.
    Accurate Silver is used quite a lot on pieces like that, but that may be a touch darker. Hard to tell. In any case, if you are going to spray the whole ring, it would look great. The benefit is it's also a car color so it can be sourced from a auto parts store in Duplicolor. On that note, stroll the isle, there's a lot of nice silver and grey metallics available to compare.
  3. vfr249240
    Florida
    FYI If anyone else has a scratched up gas cap ring, I took Captain 80s advice, took the ring to an auto parts store and I found an almost perfect color match with this stuff: VHT High temperature engine enamel, color SP995 Cast aluminum.
    mcpmartin likes this.
  4. squirrelman
    unless it's really good paint gas will hurt it. hope this isn't a case of OCD> :nelson:
  5. vfr249240
    Florida
    The can label says "oil and gas resistant" and if it catches on fire, it also says "heat resistant up to 550 deg F".
  6. 34468 Randy
    If it catches fire. get off the damned bike. Then call 911.
  7. weevee
    weevee New Member
    You could always fit a surround to cover the marks, similar to these.
    [​IMG] [​IMG]
