Comfortable Grip cushions on the CHEAP!
Discussion in '6th Generation 2002-2013' started by char, Apr 17, 2013.
  1. char
    char New Member
    Seeing how us sport touring guys like rides that end in xxx or even xxxx digits, The one thing lacking was comforting grips! So I hopped on good old McMaster Carr and found some closed cell ribbed foam tube. This stuff is rated for 200 degrees, if you are like me, and have heated grips no worries with this stuff turning to mush. I have about 200 miles on them so for darting around town and quick expressway trips and they seem to be holding up pretty well.
    The trick to putting these and any grips on is to use compressed air just start the end of the grip on the bar and cup the air nozzle around the the inner surface of the rubber grip and the foam grip, just wiggle and it will slowly slide over, no dish soap or gimmick grease.
    The larger diameter of the grip and the 3/8" cushion really makes a difference!
    Ride safe!
    McMaster-Carr
  2. Locoelectrician
    Locoelectrician New Member
    Excellent tip on using air to install them. I already had foam grip covers but have been unable to put them back on since installing my oxford heated grips. Worked like a charm. Thanks.
  3. highway star
    highway star New Member
    North Mississippi
    Good tip char! I just recently put on some cheapo foam slip overs and what a difference! Like going from holding a pencil to a baseball bat.
  4. char
    char New Member
    No problem :) ... Night and day comfort difference
  5. DMBeer41
    DMBeer41 New Member
    Which grips did you get? The course surface contoured grips? I'm thinking to get a set as the stock grips are a little skinny for my big hands.
  6. char
    char New Member
    I used 9754k24 ribbed close cell tube for 1.25 in o.d. but I am running heaters under my stock sidi grips. They last about 1500 miles but you get 60 inches of material for 20 bucks.
  7. DMBeer41
    DMBeer41 New Member
    What would I get with no heated grips...just stock?
  8. char
    char New Member
    The 1 inch should fit, your bed bet is to measure, the diameter. The material expands a bit but it will rip if you stretch it to far.
  9. mello dude
    Romania
  10. char
    char New Member
  11. duccmann
    I put some gripbuddies on over my stock grips ....made a huge difference...google it
  12. Keager
    Keager Member
  13. mello dude
    Romania
    Is probly my riding style, but I never wear out grips. Guess I do kinda easy touch on the bars, never a death grip.
  14. Hotbrakes
    Hotbrakes New Member
    Richmond, VA
    I got some of this stuff. It arrived the next day although the shipping price was not mentioned until well after the transaction. $17 for the foam, and nearly that to ship. F'ing ridiculous.
